Question about Sharp AR-M205 Copier
IBrand new machine error f5-02 change ribben cables, ccd, lamp
    President:
  • Sharp Master
  • 1,447 Answers
Copy lamp lighting abnormally. Change copy lamp
Posted on Mar 25, 2011
E6-11 display on my screen after loading document on the radf
Sharp MX7001N Error Codes
It is uncertain if this is the same manufacturer and model you are reporting, which would assist in providing a solution to you.
From web site above:
E6-11
Description
Shading trouble (White correction) (DSPF)
Causes
CCD white scan level abnormality when the copy lamp is on.
Remedy
Case 1 Cause Installation error of the CCD unit flat cable Check and remedy Check the installing state of the flat cable to the CCD unit. Case 2 Cause Dirt on the mirror, the lens, or the reference white plate. Check and remedy Clean the mirror, the lens, or the reference white plate. Case 3 Cause Copy lamp lighting trouble Check and remedy Check the installing state of the flat cable to the copy lamp unit. Case 4 Cause CCD unit abnormality Check and remedy Check the CCD unit. Case 5 Cause DSPF PWB abnormality Check and remedy Check the DSPF PWB.
Feb 18, 2018 | The Office Equipment & Supplies
Arm 205 display error F5 02 what this the solution for resetting ???/
the error F5 02 means that the copy lamp lighting is abnormal.
This is what is in the service manual:
F5 02 Content Copy lamp lighting abnormality
Details The copy lamp does not light up.
Cause Copy lamp error
Copy lamp harness abnormality
CCD PWB harness abnormality
Check and remedy
Check the copy lamp (SIM 5-3)
When the lamp lights:
Check the harnesses and connectors
between the CCD unit and the MCU PWB.
When the lamp does not light:
Check the harness and connector
between the copy lamp and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB.
Remarks Copy lamp disconnection
Cable is not attached.
You must call a tech to solv your problem.
Dec 01, 2010 | Sharp AR 201 Copier
I'm getting an E7-10 error message on my copier
10 Content CCD black level error
Details CCD black reference plate scan level
abnormality when the copy lamp turns off.
Cause Flat cable installation failure to CCD unit.
CCD unit error.
Check
and
remedy
Check flat cable installation to the CCD
unit.
Check CCD unit.
Is your lamp coming on? If so most likely the CCD assembly needs replaced, That would require replacing the carriage that contains the lamp and mirrors, the CCD is mounted to that and is laser adjusted at the factory.
Aug 02, 2010 | Sharp AR-235 Copier
Error 225
most likley has a bad lamp, if the lamp is working then the ribbon cable on the reader controler pcb maybe faulty.
Aug 29, 2009 | Canon imageRUNNER 5000 Copier
Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
We have sharp AR 206 F502 code is coming what is this code and how solved the metter i change the lens unit,optical unit,expouser lamp,cable but stil the code please help me what i do thanks
F5-02 - Exposure lamp blown
**ALWAYS DISCONNECT POWER BEFOE WORKING ON MACHINE****
Check the exposure lamp, if defective replace.
Check inline exposure lamp fuse, if defective replace.
Also check flat cable from CCD to MCU PWB , if cut or defective replace.
Last -- brds (boards)
Feb 01, 2009 | Sharp AR-207 Copier
Sharp AR C-330 Error Code E 710
E7-10 refers to black shading correction.
sometimes caused by a poor conection between the icu and the ccd. check ribben cables.
Nov 28, 2008 | Sharp AR-C270 Color Copier
Fujitsu M4099D
First, you didn't say whether the Front lamps are actually lit. I know that it is difficult to tell on this model unless you cheat the lamp interlock switch and fire up the unit into scan mode.
Front Lamps errors can also be generated by a loose front camera cable. There are no dedicated lamp detectors. The 4099 uses the camera's ccd's to detect if the lamps are burning. It is also possible, but less likely , that the lamp fuse on the main board (slides out from rear) is blown. (Fuse part number CA53004-0227).
From previous experience, there is probably a 95% chance that the issue if coming from a loose front camera cable. Not the kind of thing to get in and check unless you are service savy. I have had several calls that drove me nuts with this issue until I reseated that cable onto the camera.
The Fujitsu service manual list these possibilties :
a. Do the Front side lamps lite up when you attempt to scan?
b. Is the lamps correctly seated?
c. If the lamps don't light up, possible lamp inverter problem or fuse problem.
d. Is the glass surface and white sheet guide clean?
e. Are the connectors at the front camera ccd loose?
f. Is the power supply output normal?
g. Possible front camera failure.
h. Possible connections from camera to the Rom board problem.
Jul 11, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Photo copier c128 balck& white
That is an issue with the scanner.
1. When you turn the machine on, with the document feeder do you see the lamp coming on?
2. Shut the machine off and disconnect the cables from the scanner and document feeder, reconnect them and turn it back on.
If that is not it, A service call is the best thing to do, it is a calabration error in the scanner.
arrwup.gifDescription At the adjustment of CCD output after power on, CCD does not make a correct output which it should when it receives a specified amount of light.
arrwup.gifInitial Action
  • Refer to BSD 6.3.
  • Power OFF/ON
arrwup.gifProcedure Check the lamp, lens, mirror and the white correcting plate for abnormalities such as contamination and deterioration.
Abnormality such as contamination or deterioration of the lamp, lens, mirror or the white correcting plate is found.
Apr 18, 2008 | Xerox CopyCentre C128 Black and White...
Erro code c26
C26 indicates Peak Detection Error.
U need to check whether the lamp light on when u ON the machine.
If no, u need to check the inverter cable, inverter board, or exposure lamp.
If light is ON, then u need to perform following:
1. Check if the connectors on the CCD and SLG boards are disconnected.
2. Check if the shading correction plate is dirty.
3. Check if the conductor pattern on the CCD board is short- or open-circuited.
4. Check if the conductor pattern on the SLG board is short- or open-circuited.
5. Replace the lens unit.
6. Replace the SLG board.
Apr 08, 2008 | Toshiba E-STUDIO 650 Copier
Sharp AR-M205 Copier Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
