Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Often water left in base of drawer upper and or lower... Not cleaning well. Powdery substance on dishes
  • Fisher and P... Master
  • 3,247 Answers
Assuming you are using the correct rinse aid and detergent, my opinion is that there is muck in the drain hoses.
If you have cleaned the area under the filter plate and there is no difference, then I suggest you buy two Finish dishwasher cleaner kits from the super market.
Follow instructions on the kit and run empty drawer (one at a time) with the kit in it and at the longest cycle which will ensure a temperature of atleast 60deg.
See if there is any difference.
Posted on Mar 16, 2011
Why is the swing arm that is under the upper drawer not getting any water?
The pump may have failed, or the pump intake (under the lower drawer) may be clogged with crud from years of washing dishes. It can be removed for cleaning, although it's not a super-simple job.
Aug 01, 2014 | Kenmore Dishwashers
Powdery **** left on dishes after wasing
If you live in a region with hard water, dishwasher detergents don't work very well anymore. The govt outlawed phosphate as an ingredient in detergent. Weird but true. Look at this map to see if you have hard water. If so, try cloudydishes.com
http://www.citriclean.net/why-citriclean/
Mar 18, 2013 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I have a white powdery substance left on my dishes and they are not cleaning properly
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Oct 11, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
The upper and lower dish drawers leaves a puddle of water under each (maybe 6" in diameter) after the shortest cycle. There is a small amout of water left in the clear protective housing on the underside...
The drawers slide on a pair of rails on each side of the housing.
see installation manual page 7 to find out what you need to do to get the drawers out. The instructions are for an older model but it should be similar setup for your model.
May 18, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
The dishes are coming out all cloudy and seem to have a film on them. It is a powdery substance that will not wash off even by hand. It is ruining my dishes. It doesn't matter what soap I use.
Be sure to use a good quality detergent or tablet with rinse aid built in... but before that I would go buy a dishwasher cleaning solution. These are usually in a bottle and you just sit the bottle in the dishwasher by itself (with no other dishes) and run a normal washing cycle. The cleaner will clean the inside of the dishwasher, including the drain area and help produce cleaner dishes thereafter. This should be done every 3-4 months as standard.
Aug 19, 2009 | Whirlpool 24 in. Portable Dishwasher...
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Having a problem with a white powdery substance Model 17602
The sump may be full of debris here is how to check it:
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 28, 2008 | Kenmore 24 in. 17602 / 17604 / 17609...
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
371 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
