Question about Behringer B415dsp Eurolive 600watt 15 PA Speaker Nib
Behringer b415 horn stop working how and where i get replacement
  • Behringer Master
  • 5,603 Answers
First thing is to test the horn as the crossover circuit may be the problem. If you need the part(s) for the crossover you can get them via DIgiKey.com, however repalcing the horn driver you may have to go through FullCompass.com and if the part has to come from Behringer it takes months.
Posted on Mar 16, 2011
Behringer B205d...Is it worth fixing if speaker voltage was used in input? Main board burned out I suppose. Mfg date is 2009. No power now, was smoking from overload when it happened.
It's probably not cost effective to repair it' Check the horn driver and the raw woofer to see if they are still good, and if so retain then as spares.
Jan 02, 2017 | Behringer Music
I have 3 behringer b615d and all of them the horn speaker have spot playing. do you know what could be the problem
Generally, there are two possible problems- The horn diaphragm is blown or the power amp to the horn is broken. The diaphragm being blown is more likely. Remove the driver and run a voltmeter across the terminals. If it doesn't show continuity, replace the diaphragm. If it does show continuity, take the cabinet to the repair shop.
Oct 03, 2014 | Behringer EUROLIVE B615D 15"" Active PA...
I have 4 behringer b 615 d. And 3 of those the horn have stop playing
There are really only two choices. Either the horn amplifier in each cab is blown, or the high frequency horn driver diaphragm is blown. It's easiest to check the diaphragm first. Open up the cabinet so you can get to the horn driver terminals. Put a voltmeter across the terminals and check for continuity. if it shows open, you've found the problem. Open the driver and replace the diaphragm and you're done.. If the horn driver tests good, it's time to take the cabinet into your local electronics repair place to have them check out the amp section.
Sep 15, 2014 | Music
Bass went out
The 15 inch woofer is blown and you are hearing only the tweeter horn. I would definitely check that speaker on something else though, because the amps inside will also blow fairly easy, and you can't get parts for these. I would salvage what you can and move on. If both speakers work alone, check connections and amp. If you find that the 15 does work, then make an unpowered monitor. Behringer does not give any referencing of any parts. They have all special part numbers that you can't crossreference to find replacements. This is a marketing strategy to eliminate others from repairing, so you will buy another one. They think they would sell more but it just turns musicians away from their junk. The only piece of behringer equipment worth using is the FCB1010 controller and nothing else.
Mar 14, 2014 | Behringer Eurolive B115D Powered PA...
Why did my Behringer b212d horn stop working.
The problem is bad high freq. IC TDA7293.
There is no pasive crossover.
Nov 30, 2012 | Behringer B212D Powered Speaker (550...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Apr 12, 2012 | Behringer Ultrabass Bxl450 45w 1x10" Bass...
Rattle/vibration in the horn of my 4x10 cabinet
Open cabinet and look for loose wiring. You may have blown the tweeter horn if nothing is loose.
Aug 25, 2011 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
I have a b415 dsp speaker that I pulled apart due to a rattle in the driver. I need to confirm the correct wire color to the speakers. I believe the red and black went to the driver and the blue and yellow...
Way to find out: The minus speaker leads go to ground at the amp and therefore are electricaally connected together... just use an ohmmeter to find which two wires are tied together and connect those to the minus leads of the speakers.
Jan 12, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer B415dsp Eurolive 600watt 15 PA Speaker Nib Logo
438 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
