I already insert the required password for our wifi in our company but it always failed to connect
  • 604 Answers
Contact your IT director or administator, maybe the password has been changed and they forgot to tell you. If you are the one who set up the router, your best bet is to reset the router to factory default and reset the password and etc.
Posted on Mar 16, 2011
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Can't get internet on galaxy five without wifi
When you're at home, you're connected to your own wifi for which you have entered the password into your phone at some point. If you're away from home, you would need to be either connected to an open wifi network (not password protected) or have the password to any wifi hotspots your phone sees. Go into your wifi settings and see what networks are available. You will see a signal strength indicator next to each wifi network name, and also an icon that indicates whether the network is secured or not. If you tap on any of the networks, the open ones should allow you to connect, and the secured ones will ask you for the password. Your phone can't automatically connect to any secured networks unless it has the password. For any networks that don't require a password, you may still need to tap that network in your wifi list so your phone knows you want to connect to it, and your phone will then connect to it automatically whenever you're nearby, unless you're already connected to a stronger wifi network.
Sep 14, 2017 | Samsung Galaxy S 4G Cell Phone
Can not connect tablet to wifi
The tablet connection requires the password be input in order to make a connection to the WiFi. Look at the Router's label for the passcode and write it down. Insert the code into the command line in Open Network Sharing (command line). Once you have permission, it should work.
Jan 28, 2014 | Netis Systems wf-2404 Wireless 11n 300mbps...
Ex'3MOBILE
If the authentication password is legal and correct; you would connect. The only way a connection fails is if the password has been changed or you are not the administrator.
Contact the Router manufacturer for details on how to reset the system.
Jan 17, 2014 | Computers & Internet
Bt voyager 2110
If you're talking about the Security Code/Password that you need to access a WiFi connection, that passcode is set by whoever set up the Login requirements on the router itself. You have to get that password from that person or the WiFi Router Admin page (if it's your personal WiFi at your home) If it's a Modem/WiFi unit from your Internet Service Provider (cable company), then you should contact them for the password (if they were the people who set up the password).
Dec 22, 2013 | Computers & Internet
Requiring password
If your wireless access suddenly requires a password, one of two things has happened...
either you are inadvertently trying to connect to a neighbor's wireless router, or someone has modified your router.
If you are certain it is your router you are attempting to connect to, and it is requiring a password you did not setup, your best bet is to perform a hard reset. There should be a reset button on the back of your router. You should press and hold this button for a few seconds. This will clear all setup information and return the router to factory setup.
In order to setup your router from this point, you will need to connect directly to the router, perform whatever setup options you prefer, and then you should be able to connect wirelessly.
It is highly recommended that you setup a password for wireless access. It is also recommended you change the admin password to prevent someone else from making unwanted modifications.
Jun 18, 2013 | NetGear N600 Wireless Dual Band Router
Samsung corby 2 (s3850) wifi connection. It can't connect to the wifi. It always end up DNS failed.
Verify that you have the correct security protocol and password. Are you sure the router has a good connection to the Internet service provider? If it doesn't, you'll get a DNS failed message on every device connected to the router.
Jan 16, 2012 | Samsung GT S3850 Corby II
I just purchased a Nook eBook and I need my WiFi password to make it work. How can I create and reset a new password?
I assume you already have WiFi, if you don't, I suggest going out to wal-mart and buying a cheap wireless router to get you started. Then the instructions should explain how to get the password set up.
If you already have WiFi and the problem is that you forgot your password, then this should be able to be fixed easily if you know or have not changed the password for your WiFi router. Below is a set of steps to resolve the issue. The only requirement is a computer connected to the same router via WiFi or Ethernet.
1. Open Command Prompt (in windows) or open Terminal (in Mac OSX) 2. In the command line, enter "ipconfig" and press enter. 3. Look for Default Gateway and remember the corresponding IP Address. (Format: ###.###.###.###) It might look like 192.168.2.1 but not necessarily. 4. Remember that IP Address (write it down, copy it, do something). 5. Open your favorite web browser and enter that IP Address into the URL box. 6. This should ask you login, if it doesn't, skip step 7. 7. use the username that you set up the router with, or if you didn't change it, try using "admin" as the username and "admin" as the password. Try not using a password. If you still can't figure it out, use google to try and find the default password for your brand of router. 8. Once logged in, you can restore factory settings, or change your WiFi Password.
Having more information would have been helpful. (Aka - Router Brand, Is it your router, are any computers connected to it) Hope this was helpful.
Jul 17, 2011 | Barnes & Noble nook color eBook Reader
Itouch connect to wifi issue
Could you be more specific with what the issue is?
Home Wifi?
Router type?
WEP or MAC filtering enabled?
Did you already configure your Wifi settings:"If the network
requires a password, tap Security, tap the type of security the network uses, and enter
the password."
Dec 29, 2008 | Apple iPod touch
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
