I had a monitor on my old comutor screen so i could check if my inks if they needed changing .have a new computor and cant find it .is there a solution
  • 71 Answers
Sounds like you need to download the full driver pack for your printer. If its an HP printer, go to HP's site, Dell printer, go to Dell's site, etc. Download the full pack, usually the biggest in size has all the little configuration / monitoring tools.
Posted on Mar 16, 2011
Testimonial: "was a great help thanks "
Error code 1688 check ink coloured-replace cartridge still does not print
you cant refill this cartridge you need to buy new one and replace to old cartridge
Oct 03, 2013 | Canon Pixma MX452
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
New gaming computor hooked to new lg monitor stays in power save mode cannot see anything else on screen
looks like the screen is not being activated properly by the PC... usually if a screen is not connected it will give a message stating that it is not able to detect a connection.
ok, have you used either one of these devices before? (IE do you know that either of the definately works....)
if you can.... can you fit the "old" monitor or a "spare" monitor perhaps even one belonging to a friend to the new Computer, this should verify that the PC is working....if this method works (you can see output from the computer) then the New monitor is not working properly...
if the Known working monitor fails to show computer output then there is a problem with the Computer... you should double check by testing the new screen on a known working computer to verify that the monitor is ok
if either of these are faulty, as they are "new" you should be able to get a replacement from your supplier
hope this helps
Jun 19, 2010 | Computers & Internet
Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Dec 10, 2009 | Computers & Internet
Installed new ink, cleaned & ran nozzle check, working good but computor still says low ink
When an ink tank becomes empty. ("No
ink error" displayed on the monitor, or
short flashing of an ink tank LED)
To replace the empty ink tank.
Oct 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
Computor won't start
THAT YOUR MOTHERBOARD PROBLEM RE ASSAMBLE YOUR PC CHECK YOUR POWERSUPPLY ITS WORKING OR NOT
Sep 27, 2008 | Gateway Computers & Internet
Computor monitor
The backlight or the power-supply or the inverter. Try replacing capacitors in the Power-supply, any of the larger ones. Backlights:
various lengths are available on eBay for about $20
Jan 24, 2008 | Computers & Internet
540n screen is bright white
Due to it is new monitor the best way to solve problem is to take monitor back to seller and afterclaim it. Malfunction is inside monitor and you are not able to fix it.
Good luck
Dec 11, 2006 | Samsung SyncMaster 152N 15" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
