Question about Whirlpool Microwave Ovens
After banging the door hard the controls won't work and no electrics appear to be working to the appliance. Fuse is ok.
  • Whirlpool Master
  • 6,771 Answers
Probably what has happened, one or more of the door switches has become damaged and will need to be tested and replaced. The door switches is part of the circuitry, and is there for safety reasons if something goes wrong.
Posted on Mar 16, 2011
    Brigadier General:
  • 8,909 Answers
I expect there will be a damaged or dislodged door interlock switch stopping it from working.
Arcing and bang noise
The arching is probably to the cabinet where paint is missing. This usually occurs at the edge where the microwaves travel into the cabinet. You can get microwave paint from your local appliance parts supplier. It's special paint that is non - conductive.
May 17, 2014 | Sharp R959SLMA 900 Watts Convection /...
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
The appliance was not in operation when suddenly all the lights light up on the controls and the fan operated acrid smell of electric burning, no fuse blown but a bang was emitted from the appliance. What...
I would recommend that this product be taken out of service, especially if it is no longer working it seems as if the control board has some internal problem which could have cause this malfunction. If it will work you should at least unplug when not in use.
Aug 25, 2011 | Microwave Ovens
I have power to the unit, I checked the fuse - OK - nothing working on unit
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse intact in supply lead but Neff H5470NO appears 'dead' - nothing working and no indicator lights is there another fuse ?
Hope this helps.
Feb 16, 2011 | Neff H5470 Microwave Oven
Over the range microwaveoven worked flawlessly then bang it quit.it looks like its been unpluged but no. I tested the electrica outlet and ther is power. Is there a reset button within the microwave that...
you have a blown fuse.unplug the microwave. remove the vent by unscrewing the 2 screws holding it in place. gently pull vent grill forward to remove. open the door, and remove the screw holding the control panel in place. remove the metal plate being held in place by that screw. inside that panel is your blown fuse. remove the fuse and replace. reassemble the microwave. plug it back in.
Feb 08, 2011 | Panasonic Microwave Ovens
On a goldstar microwave oven model mv-1500mg, after pressing the light button, there was a bang and then no power to anything. I have checked the electrical outlet and there is no problem. Thanks for your...
Hope this helps.
Dec 19, 2010 | Goldstar MV-1526 Microwave Oven
Microwave has no power
Hi
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Thanks
Rylee
Jan 15, 2009 | Whirlpool MH7135XE Microwave Oven
Our microwave is a GE Spacemaker, Model # JVM1630WB004, mfg. in Mar, 2001. Just today it suddenly decided not to function other than the light in the oven coming on when activated, etc. It does not cook...
Fuses
Door switch
Oct 27, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
