Question about Samsung SL605 Digital Camera
When shutter button is pressed "CARD LOCKED"
  • 3 more comments
  • albrom Mar 16, 2011
    does not work
    still not working
    samsung sl 605 when shutter button pressed "CARD LOCKED" appears on screen Previous expert said clean contacts with alcohol. No help. No further response
    Thanks It works Can I ask for you for any further problems?
    Very helpful
  • 6,831 Answers
Hello
Thank you for using Fixya!!!
Before you try anything, try using another card. If the problem persists, try the suggestions below.
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
when shutter button is pressed
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Mar 16, 2011
  • Andrea Lock
    Andrea Lock Mar 16, 2011
    Hi, yes. If you have any further problems you will be able to request to talk with me specifically.
    Glad it did the trick.
    Kind regards
  • 734 Answers
Remove memory card and inspect it for lock switch position. Unlock it, then try your digital camera again. If same trouble again, inspect and clean all contacts in camera and on memory card too. Use cotton or paper with rubbing alcohol to clean contacts which are gold plated.
  • Arthur Tang
    Arthur Tang Mar 16, 2011
    It is obvious, that electronic circuit may have became faulty, and you have to service it. But it may just be contact resistance problem, cleaning of contacts is both cheap and may be lucky.
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
When pressing the shutter button it does not take the picture and shows a blue screen saying "card protected". Is the memory card defective?
Remove the Card and while looking it card with metal contacts facing away and up there is a little white button on top left of card that Button slides up and down up for protected mode down for unprotected slide the button down then reinsert card and try taking another picture.
Thumbs Up if helpful, feedback is appreciated.
Good Luck!!!
Jun 16, 2011 | Vivitar Cameras
When I set my Nikon D3100 on and it is in auto mode, in the screen comes message " Error. Push the trigger again". And when I push it appears again and again. I Can't take any pictures at the...
hiyou first distinguish what it cause. I suggest separate body and lens. Please enable without memory card.( remove memory card), Set to Bulb speed on Mode. Press hold and see front of camera, you should see mirror up and shutter curtain fully open inside ccd image sensor surface. Release shutter button. See what error message come out.
Jun 03, 2011 | Nikon D3100 Digital Camera
"this memory card is locked" appears on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card and see what happens with that one.
May 13, 2011 | Panasonic Cameras
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
I pressed the "on" button
Move the slide switch on the side of the card.
Feb 01, 2011 | Cameras
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
I have an Olympus C-740 Ultra Zoom Digital Camera. I bought a new memory Card. This camera is new to me and this is the first memory card I have purchased. I do not have a manual for the camera. I am...
Choose YES for the Format option. Allow it to finish. Should work fine then.
Possible defective card if does not work after full format. Do not use any "quick format" option.
First time must be FULL format.
Nov 12, 2010 | Cameras
Faulty nikon d40
That may be the best advice :
http://nikon.com/
Jun 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Samsung SL605 Digital Camera Logo
60 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
