Question about Hotpoint 24 in. DWF33 Built-in Dishwasher
I have a hotpoint aquarius dwf33 dishwasher, it's not heating up, have checked element, have continuity and a reading of 23.2 ohms, is this ok, or is there anything else I can check, many thanks ronnie.
  • 1462 Answers
SOURCE: hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
Posted on Jun 25, 2008
SOURCE: Hotpoint Aquarius DWF50 Dishwasher, cycle
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Posted on Sep 25, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: Our hotpoint DWF33 Aquarius seems to be going
i removed the drain cover in the bottom of the dish area ( near the salt fill cap )and cleaned it out. poured boiling water in and closed the machine and ran it with the hottest setting, empty.
this seams to have cured it
Posted on Oct 15, 2009
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwash not heating the water but it not the eliment
Check and see if during the heating cycle there is voltage to the element. If not, you will need to replace the control board/module. from serial number 41011 part no is c00143209, to serial no 41011 part no is c00143207
Apr 21, 2014 | Hotpoint Dishwashers
Water not heating and not drying dishes
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
May 10, 2011 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Have a Hotpoint dishwasher DWF33. Supplied with cold water supply from mains. My problem is that water is not heating during operation. Regards, Stephen.
Always supply hot water to the dishwasher...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Hotpoint Dishwashers
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
heatman101
Sep 08, 2010 | Hotpoint Dishwashers
Our hotpoint DWF33 Aquarius seems to be going through it's cycle normally but at the end of the program the dishes are not clean, the tab drawer has opened but the tab is still hole. and there is no steam...
Oct 10, 2009 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Hotpoint ctd00G will not heat up
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Sep 23, 2009 | Dryers
I have no heat from my hotpoint aquariur ctd20 tumble dryer
The element and stats are located behind removable panel at rear of m/c.
To test , you will need a multi meter set on the ohms range for continuity check., and you need to pull the wires of the components to get a proper reading.
THE M/C MUST BE UNPLUGGED prior to this check.
Check and clean all filters, remove the front bottom left filter, and clean by running under cold water.
Hope this helps.
Plz rate my solution
Thanks.
Dec 28, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint 24 in. DWF33 Built-in Dishwasher Logo
423 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
