Question about Vacuums
Cleaned inside of microwave with all purpose cleaner, now it runs but does not heat up food.
  • 17,130 Answers
Remove the plug from the power point and make sure that you completely dry the inside of the microwave with a clean dry cloth , keep the door open for drying. If by any chance the liquid or the water has seeped into the magnetron port then it might have clogged and damaged the unit.
Please check this section inside the chamber and dry this soft spot fully before you can try to switch on the microwave.
If this wont work then check the fuse inside the unit and the thermal cut off switch if this has tripped.
Posted on Mar 16, 2011
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Tip
Microwave cooking time tip
Do not be in a rush to eat the food when your buzzer sounds. Remember, that the way the microwave functions is to let the food sit for a few minutes when it is done cooking. The food continues cooking and distributes the heat evenly throughout your food. Test for doneness after the standing time.
on Aug 17, 2010 | Vacuums
I have a kenmore elite microwave oven model 363 63692301 stoped heating food ;. fan & turntable work. HELP!
Hello, two things. The mega-tron tube is gone south, or the HV diode is open/shorted to ground which will cause to open. If the microwave meta-tron tube is bad then recyle your microwave oven and buy a new microwave oven. One can buy a new microwave oven cheaper than buying a microwave tube. GB...stewbison
Sep 12, 2011 | Vacuums
Microwave functions normally apart from heating food,fan runs and table rotates but heating does not occur.
A blown fuse near the magnetron will cause that no heating. However, if the fuse is good a magnetron tube is already defective, hence no heating with normal operation on other function.
Replace magnetron tube with similar rating and size.
Thanks for asking.
Jun 25, 2011 | Vacuums
We have the GE sensor microwave WES1358DN1WW. It was made in 5/2009 & bought in July of 2010 brand new. it worked perfect til last week. i put something in it & it started to make a loud...
It's really a pain to open them up but if your feeling up to it, it sounds like the magnatron has vibrated loose and probably disconnected a wire. Disassemble and take a pic if u need help. It's pretty straight forward once inside
Apr 02, 2017 | Vacuums
Microwave counts down but turntable does not turn and does not heat food. When it broke it stopped in mid-heating but still counted down the time remaining.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 04, 2011 | Vacuums
Everything works on this microwave, the problem is when its switched on and were trying to heat food etc its not heating the food
Please be extremelly careful with microwaves, they produce radiation. My best advise is to take it to a repaar shop and ask for a quote. Microwaves are so cheap nowadays that maybe is better to buy a new one if the repair cost over 50% of the price of a new one.
Jan 15, 2011 | Vacuums
Powers on but does not cook/heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Dec 05, 2010 | Vacuums
Danby Microwave Model DMW 607w 700 watts Does not heat food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Vacuums
Dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
Oct 18, 2008 | Dirt Devil Purpose for Pets Portable...
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
