Question about GE Washing Machines
HI WHEN I PUT CLOTHES IN WASHER IT WOULD WASH BUT AT THEEND RINSE AND DRAIN ITWONT DRAIN OUT OF WATER OR WONT SPIN
  • GE Master
  • 17,130 Answers
Two possibilities are to be checked .
first of all the drain pump/valve and filter must be checked for clogging , remove clean and reset.
Secondly the program controller must be checked to see if there is voltage to the drain valve and spin motor at the cycle timing.
Please use a meter to confirm is not the program unit is to be checked.
Posted on Mar 16, 2011
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine wont spin
It broke the drive motor to transmission coupling go to www.repairclinic.com enter model number and look for this part. It's easy to change if you know a mechanically inclined individual.
Dec 23, 2008 | Roper RAS8445KQ Top Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Machine will not empty or rinse
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Aug 27, 2006 | Zanussi F1045W Front Load Washer
Washing Machines Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
