Question about JVC SP-PW100 Subwoofer
Where do i find a connector cord for my powered subwoofer model no. sp-pwm606
    Brigadier General:
  • 8,546 Answers
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
Posted on Mar 16, 2011
Have a JVC sub SP-PWM606 all speakers work except sub. found a blown cap on what I assume is the sub's amp replaced 2 caps- still no sub
Sub woofers are basically mono amps. It's likely that either a fuse has gone, on the sub, due to the blown caps. Or more likely the main power amp device of the device blew the caps. I suspect if you replace the IC or transistor(s) on the heatsink then the device will come back to life.
Feb 04, 2018 | JVC Audio Players & Recorders
I need connector cord for sp-pwa10. where can i get it.
Hello
You haven't specified about which connector cord you wants. I thinks it will be a power cord. Power cords can be selected according to the power input socket of your device, and has no specifications. Choose the best one you can buy, and of good brand. That is all. Ok.
Apr 08, 2011 | JVC Audio Players & Recorders
Model.no sp-pwc5 the power wont come on at all how cam I fix it
sounds like the power supply you will need to change it or have it changed
Mar 18, 2010 | JVC SP-PW100 Subwoofer
We have a jvc home theater surround sound system and the subwoofer just stopped working. the model number for the sub is sp-pwc30 and we want to just replace the subwoofer any ideas how to get one?
Depending of the type of Subwoofer that required your system.
A) Amplified Subwoofer. (With 110volts A.C. cord attached to the sub)
The subwoofer electronics circuit needs repair or change.
You will find a compatible subwoofer for this type of subwoofer in audio appliance stores.
B)Not amplified Subwoofer (No 110volts A.C. cord attached to the sub)
Bring your sound system to a technician to have the soldering remaked to the devices bolted on the main heatsink.
And have the Subwoofer checked too.
This type of subwoofer can mostly be buy in kit with the satellites speakers.
And need to match thee impedance of the output of your system.
Search for ( 4 ohm or 6 ohm 8 ohm ) near the Sub outlet behind your system.
Spider Guy
Mar 15, 2010 | Audio Players & Recorders
I want to buy SP-PWM606 that WORKS! if you want to sell yours call let me know.
wtf! this is a fixing & solution website not ebay or craigs list
Feb 23, 2010 | JVC TH-M505 System
JVC sp-pwm606
Hello, it,s very possible that it,s circuit protector built in to the sub (if it,s a self powered sub) gets to the point of overload and shuts off as a protection so that the speaker won,t get damaged and also so the internal amp tha,t pushing the speaker sound is also protected since theese amps all have heat buildup, their are two types of subwoofers ,They are the powered ones and the ones that are powered bt the surround amp ,The ones powered by the stereo surround amp/tuner tend to throw out less power to the sub and the ones that have internal power are mostly higher powered , Another thing you might want to check is your polarity to the speakers and also the omage , Most home theater system speakers are 8 ohm,s but their are speakers and amps that can be changed to 6 ohm,s ..so you might want to check the speaker rating also . Well hopefully you can use theese different methods to at least troubleshoot and discount the thing,s that are not the issues , Good luck and hope theese sugestions might help you , Sincerely Glenn
Mar 01, 2009 | JVC TH-M505 System
SP-PWM505
MOst of the time it is the jack that the cable plugs into that has the problem. .
Also the jack is not broken but HAS broken the solder connection TO the jack.
If you know someone who can safely take it apart and solder, let them try.
Feb 07, 2008 | JVC TH-M505 System
JVC SP-PW100 Subwoofer Logo
378 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
