Question about Mitsubishi VS-45607 45" Rear Projection Television
Pretty much every picture has a blueish outline..
Good evening? I was hoping you would be able to help me, with out having to go to a repair shop. My projection tv has a blueish outline on every channel. When I turn on the unit it wont be there for a few seconds then it will come on. Any Ideas??
  • Mitsubishi Master
  • 8,617 Answers
Your convergence ICs need to be replaced. very easy repair on your model. You need two convergence ICs STK392-110 you can get replacement Ics at the following link with free instalation instructions with pictures and free online tech support. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 02, 2008
My camera won't work and I need it to work TOMMORROW!!
Hello Olivia, Well it is not going to be fixed by tomorrow !!!!! It will have to go in the shop for repairs.
Nov 23, 2012 | Kodak EasyShare 1445386 M340 10.2...
The picture & contents are outlined in red green ,yellow colors
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 01, 2011 | Hitachi Televison & Video
The camera works i can veiw photos i have taken but the screen goes black when i switch it to take photos ... it dont even take pictures when the screen is black
There'a a problem with with the lens or CCD (the picture sensor). Take the camera in to a camera repair shop and get an estimate first before getting it fixed, as the cost of repair often exceeds the cost of a new camera.
Good luck and hope this helps.
Dec 08, 2010 | Cameras
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
Convergence Problem
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture is dim and white is kinda blueish green tinted
Hello jeromek28,
This may be a CRT problem. From what it sounds like i.e. dim picture, colors not bright. If you have a background in electronics I would tell you to check the voltage levels on the CRT pins and compare them to the values on a schematic, however if you do not have a background in electronics, I would suggest you taking the TV to your local TV repair shop and have them troubleshoot your problem.
Here is a possible list of things that might be wrong:
1) CRT going bad (The shop can try CRT rejuvenation if needed)
2) High Voltage on the anode not at proper levels (The shop can check this with a HV probe)
3) Video output levels low (The shop can check the voltage and signal levels on the CRT socket board, and on the video amplifiers.
These are the three primary possible issues.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
May 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Sound but no picture
I suspect a Vertical failure in your Sony TV. This problem is pretty common and is relatively easy to repair. Often, this involves replacing the Vertical IC which is not that expensive. Basic knowledge of electronic circuitry and components, use of a soldering iron and an electronics part shop near you is all that is required. Of course standard safety precautions apply when working with HV such as in your TV.
Should you not be comfortable performing a do-it-yourself, perhaps you may need to seek the services of a qualified professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | Sony KV-20M20 20" TV
Double image?
Your convegance amplifiers have failed there are two of them they must both be replaced. there may also be some resistors in the convergance amp circuit that have opened. average cost of this repair is $120.00 parts and $170.00-$300.00 labor. all depends on the tech you get.
Apr 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
