Bosch classixx1200. How to get the drain cover open
    Brigadier General:
  • 6,277 Answers
If I understand you correctly you are having difficulty actually removing the cover 'cos it's stuck? Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If you are after more detailed instructions on access and cleaning the filter and checking the drain motor here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
Testimonial: "Thank you. Totally shocked to get a reply so quickly. Will have a go."
My Bosch 300 does not have a little round plate nor a square plate below my drum opening on the exterior of the washer like many posters have indicated. How do I get access to my drain filter?
These Bosch machines are similar to some Kenmore washers (he4t). You can remove the lower front cover. Behind this cover, you will find a white plastic housing that has a s tree off cover. Be ready with a catch pan! Remove this cover and water and collected debris will come pouring out in a large gush. If this becomes clogged, the washer may send error codes and fail to spin and drain properly. You can fish out additional debris with your fingers before replacing the cap and the lower front cover.
Nov 10, 2016 | Bosch Washing Machines
I have an Bosch washing machine, model WFMC6400UC 12391301. I get the drain blocked Fault notice on the control panel.I have opened the cover and observed the pump working, I have blown out the discharge...
Bosch washing machine, model WFMC6400UC 12391301 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 31, 2011 | Bosch Nexxt300 WFMC220 Front Load Washer
My Bosch front loading washer is flashing E:13 and won't open
Hi, i had an E-13 error code on my Bosch 500 series washer. The drain pump impeller was plugged. Access the drain impeller at the bottom front right corner. Just put a pen in the hole and turn the cover. Then you need to manually drain the washer. I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while. When you get it drained you can take the cap completely off. When I did I found a wipe in the impeller. I took it out and put it back together and the washer worked just as before.
Take care
Jun 13, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Washer just stopped, won't do anything, door is locked and I cant get it open its a bosch 900 rpm front load.
you can use a wet dry shop vac and attach it to the end of the drain hose to remove any water this will also unlock the door the check the drain pump for anything that would be blocking the flow of water
take off the small front cover to the drain pump pull the whit plastic zip tie and this will unloock the door.
Apr 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Jan 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Apr 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My Bosch dischwasher is not draining completely. I've taken out the mesh filter and the square plastic drain cover. Should I unbolt the white cover which I presume covers the drain? thanks!
I had the same problem, twice. Both times, the technician simply removed the drain hose and cleared it of a small food particle. Save yourself the service charge by unhooking the hose yourself, clearing it and rinsing your dishes THOROUGHLY before washing.
Feb 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
