Question about Cell Phones
HTC Wildfire won't connect to 2008 Ford Mondeo stereo. The bluetooth connection recognises the ford audio, I select & enter the passcode 0000 and the phone says `pairing' but never actually pairs. I don't get a code on the car stereo.
  • 179 Answers
Just a suggestion as I have trouble connecting to anything via bluetooth myself.
Make sure the Car stereo has the passcode 0000 sometimes the manufacturers use 1234 and they are preset so you don't have to type them in.
Also try when it is trying to pair...Switch bluettoh off then back on again. This sometimes works for me. :)
Posted on Mar 16, 2011
  • frsmith194 Mar 26, 2011
    Hi
    I to have this problem with a sony xplod.
    Phone will not see the car stereo at all.
    My Nokia n900 was fine,
    Cheers
    Bob
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
How do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
Bluetooth keeps aking for a pairing code. each 4 digit one I tried fails..says:cannot pair with ford audio..using n96 and iphone 4 both fail to pair
Did you try just pressing enter (no code)? If not, try "0000" I found something here: http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Bluetooth%20%26%20Voice%20control/bluetooth%20%26%20voice%20control%20%28cg3504en%29%2001-2006.pdf which indicates "0000" is the code, but enter should do it
Feb 04, 2011 | 2008 Ford Focus
How can i use my wildfire as a módem for my
  • Connect your HTC Wildfire to your loptop through the data cable or bluetooth.
  • Go to CONTROL PANEL.
  • Click on NETWORK CONNECTIONS.
  • Select the option CREATE A NEW CONNECTION available on the left hand side.
  • Select CONNECT TO THE INTERNET option and click NEXT.
  • Select SET UP MY CONNECTION MANUALLY and click on NEXT.
  • Select CONNECT USING A DIAL-UP MODEM and click on NEXT.
  • Give a suitable name for the ISP asked.
  • Enter *99# PHONE NUMBER.
  • Enter your mobile number in the USERNAME and PASSWORD field.
  • Click on FINISH.
  • Double click on the connection established.
  • Click on PROPERTIES and make sure your HTC is made the modem and click OK. Click on CONFIGURE to make HTC the modem if it is not preset.
  • Click on DIAL.
Follow this procedure to set up a connection making HTC Wildfire as the MODEM. The mentioned procedure is for WIN XP. It is similar for VISTA and WIN 7.
Dont forget to RATE the solution. Post a comment if you need any suggestion and i will get back to you.
Jan 04, 2011 | HTC Cell Phones
I can't connect my bluetooth keyboard
Unfortunately the HTC Wildfire does not support the Bluetooth HID (Human Interface Device profile) which enables you to connect a keyboard. It does support the following profiles; headset, file transfer, audio/video remote control, object push, audio streaming, phone book access & hands-free.
Dec 25, 2010 | HTC Wildfire Cell Phone
Want to hook uo bluetooth
First switch on bluetooth (settings---bluetooth).
Start > Settings > Communications and Add new Bluetooth headset. htc will search bluetooth headsets and find it. it will ask you to enter bluetooth passcode, usually it is 0000. then finished and you have paired Bluetooth headset with HTC
Mar 26, 2010 | HTC Cell Phones
Trying to connect bluetooth
the pascode that most people use is "0000" and the other phone is the same passcode
Sep 22, 2009 | LG KU990 Viewty
What is the passcode i enter in my phone to connect my bluetooth to my phone
If you are trying to connect a bluetooth headset to your phone, generally the passcode is "0000", but if you are trying to connect a phone to pc with bluetooth, you select a passcode and verifiy it by entering the same code in your phone.
Apr 12, 2009 | Nokia 5310 Cellular Phone
Just received a new Motorola Razr V3xx and can't get it to connect to my new BlueAnt Supertooth 3. The S3 will connect to my HTC Kaiser Tilt. Turning Bluetooth on and using the "ADD Audio Device" option,...
Code is 0000 make sure you press the green button to turn on the bluetooth light on the Blue Ant, while pairing AND when you enter the code(don't hold it down, just make sure it's on before you finish entering it).
Mar 09, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Cell Phones Logo
647 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
