Question about Casio fx-300ES Calculator
The wild geese fly in V- formation A formation of wild geese has 24 geese in the last row 23 geese in the second to the last row ,22 geese in the next row , and so on. how many geese are there altogether
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Use this formula: f(n) = n(n+1)/2, where "n" is the last number of the sequence of numbers you are adding (in this case, "n" would be "24").
So: f(24) = 24(24 + 1) / 2 f(24) = 600 / 2 f(24) = 300
There are 300 geese altogether
Posted on Mar 16, 2011
What's the dialling code to Tanzania
+255
Area Codes: Add to landline numbers only! Arusha 27 Lindi 23 Ruvuma 25 Coast Region 23 Mara 28 Shinyanga 28 Dar es Salaam 22 Mbeya 25 Singida 26 Iringa 26 Morogoro 23 Tabora 26 Kagera 28 Mtwara 23 Tanga 27 Kigoma 28 Mwanza 28 Zanzibar 24 Kilimanjaro 27 Rukwa 25
http://www.howtocallabroad.com/tanzania
Jan 07, 2016 | Cell Phones
How do i convert meters in length to liters of oxygen
You cant do that. They don't relate to each other at all. For a start your trying to compare one dimension to three.
Jan 29, 2015 | Prentice Hall MasteringChemistry Student...
How to set timing on 23 hp briggs and stratton intek v twin 23 hp
The only way to set the timing is by aligning the cam and crankshaft gears, before doing this check the shear pin in the fly wheel to see if it has been sheared off.
Oct 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Nov 09, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
There is only one number 20 and i dont know where to connect it to.
After lots of staring and wondering, I figured this out. On the big piece that makes up the bottom center of the boat, there are labels for 19, 23, and 24, but numbers 20, 21, and 22 are missing. If you look closely, that label actually shows 19-23, 24. It means 19 through 23. You are supposed to stack up the parts labeled 20, 21, 22, 23, and 24, and connect them all to the bottom of the boat where the label 19-23, 24 appears. This worked for me - I hope it helps you or someone else who looks here when they get stuck on this same problem!
Jul 14, 2011 | Woodcraft Pirate Ship 3d Construction Kit
Need diagram 2001 vw new beetle fuse panel. When I bought it did not have panel cover........thanks! problem with washer pump book says #1 10 amp small fuse and #24 20 amp no where on fuse panel says #'s
The #1 fuse is in the upper left corner of the fuse panel, actually its the top fuse in the third row down, but row No. 1 and No. 2 do not have any fuses in the upper left corner. There are a total of 23 fuses in the upper most section. Fuse #24 is the first fuse in the lower section of fuses (upper left corner of that section as well.
The block diagram for the fuse panel is also contained in Section 3.2 of your Owner's Manual. The fuses are numbered in each section from top to bottom starting in the upper left. Fuses 1 thru 23 in the top section, fuses 24 thru 44 in the bottom section which consists of three columns.
Oct 28, 2010 | 2001 Volkswagen Beetle
How to I reset the service engine?
you should go to your local mechanic and they should be able to reset it electronically.
Sep 19, 2009 | 1998 BMW 5 Series
I have diagnostic codes of 22, 23, 24 for my 1995 Saturn Sl 1
well according to your codes that i looked up for you i think its safe to assume that your timing is off. i will paste the codes so you can see for your self. i hope this is what the codes actually look like.
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
Apr 29, 2009 | Saturn SL1 Cars & Trucks
Related to c++ nested loop
Following is the code extract (please dont mind if any syntactical errors, its long time back when i've done C++ coding, but following logic is 100% working)
int x,y,z=10;
for (x=1;x<=5;x++)
for (y=1;y<=x;y++)
z++;
cout<<z<<"\t";
cout<<"\n";
11
12 13
14 15 16
17 18 19 20
21 22 23 24 25
Hope this is what you need.
Feb 26, 2009 | Computers & Internet
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Casio fx-300ES Calculator Logo
113 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
