I have a simpson 144 industrial washing machine. For no apparent reason the cold water pipe wont let water through. What could be the problem?
    Brigadier General:
  • 6,277 Answers
Providing that you have checked the actual supply is OK- tap on, no kink or squashed hose AND you have ensured the fine filter inside the machine's inlet port is clean, it's a machine fault.
This is symptomatic of failed water control valve -its physical fail/no power position is closed. It needs replacing! Service call ;-0(
Good luck,
John C
Posted on Mar 16, 2011
Recently had a leak in our water pipe between mains and house.We had the pipe replaced.Then the washing machine wouldn't fill so we replaced solenoid valve-it works now. The dishwasher won't fill now
when the pipe was repaired , there is every possibility that dirt got into the pipe and will affect all solenoid operations and taps
remove all hoses and flush the pipe out well
Oct 21, 2016 | Simpson Washing Machines
I have a simpson 9.5 kg washing machine an ezi you put powder in and it wont fill you turn the settings to fill and it wont work any ideas i was working fine then now it wont fill up
Power off the machine. Close your wall faucet which brings water into the machine. Unscrew the nut, hold a bag or bucket to collect water coming in from the wall, gently open the water control to see if water flows - the flow should be in good pressure. If it is good, close valve; now open the other end of the pipe going into your machine. You will see a fine filter connected to your machine; clean this out if clogged with an old toothbrush; clean out your pipe too. Refit carefully both nuts, without cross-threading; open the wall faucet to check for leaks. Things should be fine.
Mar 01, 2015 | Simpson Washing Machines
My simpson eziloader machine won't start - when I press the start button it clunks a couple of times then nothing - water won't enter have checked the inlet pipes
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
Feb 21, 2015 | Simpson Washing Machines
How do I change the cold water inlet valve on a simpson ezi750 thanks
issolate the mains power and water supplies
take the water off the inlet
remove the screws that hold the valve
use a pair of plyers to grip and pull back the tube clip from the reat of the valve assembly or both pipes
and the slip off the pipes
and refit in reverse
Dec 10, 2014 | Simpson Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Simpson 175 wont take on hot water
Your water inlet valve is bad on the hot water side and needs to be replaced. It is located right after the supply hose for the hot line behind the back plate
Feb 13, 2009 | Whirlpool Washing Machines
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
