Question about Ovens
How do I actually access where to replace the bulb
  • 17,130 Answers
If this is a microwave oven as it is not specified then the top cover can be removed and the Bulb cover can be taken out to replace the bulb-- choose the same type and wattage.
Posted on Mar 16, 2011
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
How i can change the lamp in my Bosch oven?
Remove the glass cover and unscrew the bulb.
Dec 04, 2014 | Ovens
How do i change the bulb in a brother hi speed cooker microwave . It is about 30 years old and works very well
If no access from the front you will have to get at it from the back. Remove the back covers, the light socked will probably be held in place by a few screws or clamps. remove the entire assembly as one unit, replace the bulb and re-install.
Aug 16, 2014 | Ovens
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
I have a Bosch HBN double oven unit. The bulb in the lower oven has broken with the screw-in base of the bulb stuck. The glass top of the bulb has come away. Cannot get the remaining bit unscrewed due to...
If you try using a thin NOSE PLIER - with a n ALIGATOR MOUTH- it will be easy to pull out by unscrewing the stuck up damaged thread of the bulb. Once it i s free even with a higly pointed screwdriver it can be pushed to unscrew.
Please try this out and it will be easy to replace.
Aug 19, 2011 | Bosch Ovens
It "popped" a circuit breaker
NORMALLY THERE ARE SCREWS TO REMOVE TO ACCESS A PANEL TO REMOVE THE LIGHT BULB. IF THERE ARE NOT, THEN THE EXTERIOR COVER MAY NEED TO BE REMOVED TO ACCESS THE LIGHT BULB. THIS EXTERIOR COVER HAS SCREWS.
MAKE SURE YOUR CIRCUIT BREAKER IS OFF BEFORE YOU TRY TO REPLACE THE BULB.
Feb 20, 2011 | Ovens
How do i replace the bulbs inside the ovens
The lenses have to be removed to gain access to the bulbs. If you look carefully at the lense, the edge immediately in front of you will have a small lip that you can get a screwdriver blade under. do so and twist the blade carefully and the lense should just spring clear. Note that the lenses have cut outs on them to ensure clearance on the bulb, so replace them round the right way.
Oven bulbs are all the same quality, so as long as you buy an oven bulb and it is the same physical size and fitting (BC or SES), you should be ok.
Feb 07, 2010 | Stoves 720EF Electric Double Oven
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Need to replace halogen bulb that illuminates Advantium interior
    Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
    Regards! --W/D--
    Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
    Change Bulbs in Neff U1661 Oven
    You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
    Bulbs available from Homebase, Wickes, BandQ etc etc.
    Apr 27, 2008 | Neff U1661 Double circotherm super...
    Ovens Logo
    44 people viewed this question
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
