The unit keeps beeping when connected to the computer and is not recognized by windows.
    President:
  • 1,623 Answers
If they are short beeps about a second apart , then the hard drive is not receiving sufficient power to it, plugging it in directly to a power connector on the motherboard should allow it to work, unless there is a major malfunction of the controller.
Posted on Mar 16, 2011
Testimonial: "I suspected as much and I am very thankful having this confirmed by an expert."
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Externel harddrive will not open on computer and keeps making a beeping noise
If your USB drive is not being recognized by your computer when you plug it in
try unplugging it, and also unplugging any other USB devices that are connected.
All USB devices, even those that have an external power supply, draw a portion of their power directly from the USB bus.
If you have too many devices connected to the same USB controller, problems such as a drive not being recognized can result.
Incompatible File System
The Mac-operating system can read drives formatted under the FAT32 and NTFS file systems used by Windows, but Windows will not recognize HFS, the file system used by Mac OS.
If you connect an HFS-formatted external drive to a computer running Windows, the drive will spin up but Windows will not respond.
The drive will have to be used with a Mac, or reformatted using a disk-partitioning utility.
Drive Disconnected from Power
Some external hard drives have the option of drawing all their power from the USB bus, or receiving supplemental power from a wall outlet.
If your drive will not operate using power from the USB bus only, connect the power supply. Many drives do not have this option; they will not operate unless they are connected to both a power outlet and a USB port.
Driver Update Required
Some older motherboards may require updated USB drivers to properly utilize a modern USB 2.0 device.
If you have exhausted all the basic troubleshooting steps above, visit the website of your motherboard's manufacturer and look for updated USB drivers.
Also, ensure that your Windows installation is fully up to date.
Corrupted Files
USB hard drives are susceptible to data corruption if either the power or USB cables are disconnected during a write operation.
Over time, this could lead to a situation in which Windows will be unable to write to the drive correctly.
To have Windows attempt to fix corrupted files, run Scandisk by right-clicking on the drive after double-clicking on "My Computer." Click Properties > Tools > Error Checking. Click the two check boxes to have Windows attempt to fix errors and bad sectors.
Click "OK" to start the operation.
Depending on the size of your hard drive and the speed of your computer, this operation can take a few hours to complete.
Failing Hardware
If your drive is still not being recognized, but it is making audible noises when it is plugged in, the drive may be failing.
Nearly every hard drive manufacturer distributes a free utility to check the drives that they make for errors.
Visit the manufacturer's website to download this utility.
If the drive is failing, the utility will most likely be able to detect it.
Contact the manufacturer for a replacement if the drive is under warranty.
Oct 01, 2012 | Computers & Internet
Palm z22 USB won't stay connected
Hi, I also had the same problem exactly the way you described it. What worked for me is putting in the original installation cd that came with the palm. Run the installation and I think the computer will recognize the palm and stay connected. Hope it works.
May 11, 2009 | Palm Z22 Handheld
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My Computer and iTunes does not recognize my iPod
Have you tried installing the ipod program cd from your ipod on a separate file. Under a different username? It may be conflicting with the older model ipod protocols. If that dosen't work try going to apple.com for further assistance.
May 12, 2008 | Apple iPod nano
Computer does not recognize device
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 19, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Computer doesn't recognize unit when connected
I am guessing there is a problem with the driver for the audio player. I have a Coby Audio Player MP-C827, and one day my brother decided to just remove it from the computer without correctly stopping it. Ever since, whenever I plug in it into my PC, it just does not open...nothing happens. And I don't have the cd to re-install the driver files. With respect to all of the above, a driver file which is needed by the mp3 is either damaged or corrupt. Contact me at ramone.williams89@gmail.com
Dec 29, 2007 | Coby MPC-848 MP3 Player
Hey
try{MS_AddEvent(window, 'load', function() {try{CreateAC({id:'query', lcid:'1033', initialValue:'', acURL:'http://autocomplete.support.microsoft.com', statsObj:StatsDotNet, startChar:'4'});}catch(e){}});}catch(e){}
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Computer won't recognize
Sep 25, 2007 | iRiver H10 MP3 Player
Computers & Internet Logo
942 people viewed this question
David Payne
David Payne
