Question about Hitachi 3 - 1/4" Framing Strip Nailer
Product NR83A2. Lubricate is coming from the trigger and exhaust cover. The nailer is new and I put lubricate in the gun prior to placing the air plug on. What is the best way to drain the excess lubricate from the gun. The manual indicated to add 5 to 10 drops to the gun after nailing. I put a great deal of lubricate in the gun prior to using.
    President:
  • Hitachi Master
  • 1,388 Answers
Excess oil will eventually be consumed /blown out of gun, however if you store the gun over-nite with air inlet pointed down, gravity will assist. I find that oil /water will accumulate inside gun especially if compressor is passing oil and/or weather conditions cause system to produce lots of water. Majority of guns that come in for repair suffer from a lack of lubrication. Several drops at start of day should be ok for oil lubricated compressors and maybe more for oil-less. If oil drips out of gun overnight (if stored as stated above) then reduce drops. What actually shortens life of gun is debris that enters gun from handling and that enters hoses during transport. Before connecting air hose to gun (with hose under pressure) momentarily connect a spare quick connect fitting and blow debris out of hose.
Posted on Mar 16, 2011
When my Senco SLP 20 brad nailer is connected to air hose, air will blow-by through the exhaust. After you fire a couple of pins blow-by stops
Most problems with this gun centers around the firing valve part # Bao119 . This part must not get any oil because it will swell and begin to fail as you describe. That being said, the trigger valve does need some type of lubrication or it will become sticky causing problem that you describe. If you have been using oil in the gun, most likely inner trigger parts will be lubricated and failure is firing valve. If no oil has ever enter the gun, suspect the trigger valve. It will need to be removed from the gun and lubed with white grease or silicone lube. Good luck
Dec 05, 2014 | Air Tools & Compressors
My frame pro 601 will sometimes shoot one to five times and then when you pull the triger nothing happens air comes out the core valve hole above the trigger when pulled then you can unplug air and tap on...
Senco makes a kit for your nail gun, part number YK0360. If you have any o-rings giving you problems, it's always best to replace all of them. You can get them from online parts stores like eReplacementparts.com or possibly from rental or repair places near you. Make sure you lubricate all the o-rings well when putting the new ones in.
Dec 13, 2012 | Senco & Frame Pro 601 Framing Nailer
Gun leaks
No it is not. It should not leak at all. Where is it leaking air from? The 3 obvious places are the exhaust at the top of the head, the nose where the driver comes down, and the trigger valve.
Jul 29, 2012 | Campbell Hausfeld 2-in 18 Gauge Brad...
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
My dewalt framing nail gun was hooked to the air compressor, but was not being used when it began leaking air which you could hear and got louder. It sounded like it was leaking around the trigger area....
There are O-ring seals around the trigger that are probably leaking. You can try to lubricate the gun by adding the pneumatic oil to the air supply. That may be enough to seal it back up. Otherwise the seals and/or the trigger assembly will need to be replaced.
Dan
Mar 29, 2010 | Dewalt Round Head Framing Nailer D51845
Hitachi nail gun nr90ad leaks from trigger when air hose is connected
Orings, they have to be replaced every few years. Warranty does not cover them.
Any Hitachi service centre should stock them. Or find your model on Ebay:
http://shop.ebay.com/i.html?_nkw=hitachi+o-ring+kit&LH_IncludeSIF=1&_arm=1&_armi=0&_armm=20&_ruu=http://shop.ebay.com/i.html%3F_nkw%3Dhitachi%2Bo-ring%2Bkit%26_arr%3D1&_rdc=1
Hope this helps!
Thanks
Jan 20, 2010 | Hitachi Air Tools & Compressors
Framing nailer, dewalt d51823 doesn't fire. Orings appear to be intact. I can feel oil coming out by the trigger and air leaking when I try to fire it. Otherwise there are no leaks. I have an identical...
Generally, when you attempt to fire and only get an air sound at the trigger, the problem is air leaking past the orings in the head valve. Here are a few things to check and a simple test.
Remove the trigger from the gun so that you can have access to the trigger pin. Remove the nails from the gun. After removing the trigger and the nails, reconnect the air supply (check for 100psi) Place the nose of the gun against wood and with a very quick ****, depress the trigger pin all the way in. If the gun fires then the safety foot is not allowing the trigger to depress the pin all the way in. Make adjustments to safety and check for worn trigger and trigger retainer pin. If the gun does not fire, remove the head. Place the head on table and depress the headvalve all the way in with your thumbs then place a finger over the small vent-hole on the gasket surface and release thumb pressure. The headvalve should remain depressed due to vacuum in the valve and will pop up when you remove your finger on vent hole. If the headvalve does not stay in, air is leaking past the orings. Remove headvalve parts and use magnify lens to find small scratches on the surface where orings contact. Remove scratches with very fine sandpaper (300 - 400 grit) Make sure all the orings are not cut (use magnify lens) and fit snuggly. Lube with "Danco silicone grease" available at lowes in the plumbing department. It is used to lubricate orings in faucets. After re-assembly, do vacuum test as described above. If you have vacuum, head is ok. Make sure that the gasket seals around the vent hole where the head mates against the body. You should be good to go. Good Luck and email if you have other questions.
Mar 04, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Sep 24, 2008 | Hitachi NR83AA3 3 1/4" Clipped Head...
Hitachi 3 - 1/4" Framing Strip Nailer Logo
156 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
