Question about Samsung Televison & Video
FUNAI WD5B-N8480ZB CONNECTED TO SAMSUNG TELEVISION VIA HDMI. WHEN PLAYING DVD NEED TO TURN SOUND ON TV NEARLY TO MAXIMUM TO GET REASONABLE SOUND
  • 604 Answers
If you haven't alread, try connecting your tv with the standard RCA connectors, (for the audio) you may have to also connect the yellow video cable depeding on your system. If the audio is low level with these connectors, the problem may be the TV itslef. Aother option is to plug something else into the tv audio inputs (again you may need to have something plugged into the yellow video input. good luck
Posted on Mar 16, 2011
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
I have the Samsung HT-C550 home theater system and a Sony 42" HD TV. The two devices work well when playing a DVD but when I watch TV I can't get the TV sound through the home system. I am...
Try this:
Purchase a 3.5 mm jack (it will have a smaller connnector going into the TV and Red and White connectors on the other end).
Pull all the other cables running into the Blu Ray player out so that you are only left with the HDMI Cable coming from HDMI Out (DVD) to HDMI/DVI In (TV), along with the 3.5 jack.
You will be able to play the TV sound through the system.
Jan 13, 2011 | Samsung HTC550 Theater System
No sound or picture from dvd
And you have selected the HDMI2 input in the TV menu? If yes, try the dvd on another TV, if you have one. Also try reversing the HDMI cable.
Jul 01, 2010 | Bush DVD2038 DVD Player
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
It sounds as if you need to turn the TV's built in speakers off.
Apr 13, 2007 | Network Associates IDIQ WEBSHIELD HTTP...
Open Questions:
Televison & Video Logo
177 people viewed this question
Jerry Greenberg
Jerry Greenberg
