Question about Nokia N95 Cellular Phone
My n95 screen appears white blank , and i dont know how to fix it ? whats wrong with it? and can i do anything to fix it ?
  • Nokia Master
  • 17,130 Answers
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Mar 16, 2011
N95 black creen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Good luck.
Aug 27, 2010 | Nokia N95 Cellular Phone
My nokia n95 light on my screen dont light up
if you mean you just have black screen.buy new one off ebay.got mine off kgm_sports. came with tools as well and works a treat,well recommended.£9.99 free p&p.and video instructions on you tube.very easy,i'm no tech.fixed in ten mins
Jan 18, 2010 | Nokia N95 Cellular Phone
Screen blank after fitting orange sim card
I had similar problem. Try: Remove battery, sim card and data card. Replace battery and turn on. This fixed my screen problem. Then I selected factory defaults from general settings, though I dont know that this was necessary. Cheers
Dec 20, 2009 | Nokia N95 Cellular Phone
N95 display gone suddenly........do no Y ? ??
cost would be very less dont worry try reloading thhe software
Jul 03, 2009 | Nokia N95 Cellular Phone
I have a Nokia N95 8gb and in anger threw it across the room. Its is now well and truly broken. I have experiance with repairs, so have tried to repair it myself. I fixed the slider problem but on power...
You can find replacement LCD screens for N95 in this link. There is also a video explaining the installation:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/N95
Note that N95 and N95-8GB have different LCD screens.
I hope it helps.
Ignacio del Olmo
May 30, 2009 | Nokia N95 Smartphone
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Apr 05, 2009 | Nokia N95 Cellular Phone
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Go throught this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Your ipod might need to be repaired, the apple service assistant is on the bottom.
Might be a loose connection or other failing component I don't think there is no quick fix for this.
If the problem is solved dont forget to rate as fixya otherwise there is no need to rate it. As there is noting else we could do about it.
May 15, 2008 | Apple iPod nano
Nokia N95 Cellular Phone Logo
277 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
