Question about Bosch Integra® 500 SHX46A0 Dishwasher
Turns on but do not hear water going into dishwasher
  • Bosch Master
  • 17,129 Answers
Possible that the inlet valve is blocked at the filter end. You will need to check the voltage to the inlet valve,if present without any action then the valve is choked or faulty.- try to clean and reset.
If there is no voltage then the program controller unit is faulty.
Posted on Mar 16, 2011
Dishwasher has no water
Find out where your water supply is turned on to your dishwasher. Usually it is under the sink and make sure the valve is turned counter clockwise to supply water to the dishwasher. If this is on, on some models there is a float switch that will sometimes get stuck in the overflow position. Look in the bottom of the dishwasher tub and you will see a round float. Usually it is in the front left of the dishwasher. Move the float up and down and you should hear a clicking noise. Make sure float stays in the lowered position, closest to the dishwasher floor. Check those two and let me know what you find. And we can go from there.
Apr 01, 2012 | GE Dishwashers
Dishwasher stops running and won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
hhf
May 13, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Water is not going into beko dishwasher de2542f .you can hear and feel water going through the pipe but is not going into machine
My BEKO dishwasher is turned off but there is a constant dribble of water running in to the machine. If I open the door when this has happened, it leaks water all over the floor. This means I have to keep turning the machine on to drain the water away.
Feb 06, 2010 | Beko 24 in. D3731F Free-standing...
ADP7966 flashing F4? What is the problem ? Looks like there may be a blockage at the bottom where the salt goes but not sure?
Just moved dishwasher to another location across the room. Water connected fine, electrictiy connected fine. Turn on and you can hear pump going but that's it. No water going in?
Jul 19, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Thermador dishwasher DWU244, error code "F" does not run?
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
Feb 15, 2009 | Thermador DWU244 Dishwasher
Bosch Exxcel Auto option
There should be a float switch inside the dishwasher sometimes these get hung up on the full position which in turn keeps the solenoid from allowing the water to come on. remove the bottom rack and check to see if this is the case. Dislodging the float should fix the problem. If not listen to see if the solonoid Clicks when you turn the cycle to fill position if not it could be either solonoid or the timer. if you hear click and still no water check strainer in water line could be clogged or water is turned off some where.
Oct 19, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Whirlpool dishwasher
Hi jamesward,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher turns on and you can hear the motor but there doesnt seem to be any water going in
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Dishwashers
Bosch Integra® 500 SHX46A0 Dishwasher Logo
119 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
