Question about Samsung SCX-6322DN All-In-One Laser Printer
Hi Everybody, My 6322DN says "printing...", you
  • 310 Answers
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Posted on Mar 16, 2011
Faxes will not go through, says
Try changing your resolution to FINE or SUPERFINE Make a copy to verify the FAX MFC scanner operation.
Apr 11, 2012 | Brother IntelliFax-2820 Laser Fax
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
How do i do double sided printing on a multi express 6322dn
hello
these two links will help you figure out HOW TO PRINT DOUBLE SIDE COPY
it is all in the control panel on the printer--very simple to use
http://downloadcenter.samsung.com/content/UM/200910/20091027131536375/Guide_EN.pdf
manula in PDF
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=SCX-6322DN/XAA&srchword=SCX-6322DN
Samsung side to download
please help me keep my job - send me 4 thumbs up
Aug 23, 2011 | Samsung Office Equipment & Supplies
I have a Lexmark 7170. I want to print a document from my computer. Unfortunately, when print is selected, the printer will perform as though it is scanning or copying. How can I get it to perform a print?...
Even though the Mode is on Copy on the Printer it would still print if you send a Job from the Computer!
Since When are you facing this trouble?
Whats the Operating System on this Computer?
Aug 06, 2011 | Lexmark X7170 All-In-One InkJet Printer
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
FIRST PAGE PRINTING AFTER SENDING FAX
Scroll through the menus for REPORT PRINT to set confirmation.
Jan 27, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Samsung SCX-6322DN All-In-One Laser Printer Logo
129 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
