Question about Nintendo Wii Console
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black & white .??
  • 44 Answers
It sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Posted on Mar 16, 2011
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
I just got a new 46" vizo & dont know what ports to plug my wii into? i know the cords are red white & yellow but not the ones on the tv. totally confused.
Many large HDTV's will have alternately colored slots to enable 5 connector HD cables. You can plug the Red White and Yellow cords into non-matching ports (green, black, etc) until you have color picture and stereo sound. This will not damage your TV or Wii. You can also buy cables for your Wii that will match the connectors on the back of your television, as well as give your Wii higher resolution capabilities. Which you can purchase at any electronics store.
Mar 14, 2011 | Nintendo Wii Console
I got a new nintendo wii today and everything works fine but the sound doesnt come on what should i do? i made sure everything was lined up right
The quickest thing you can try is to connect it to another TV and see if it works.
There are various methods for connecting the Wii to the TV. In the box you should have a component video lead with red, white & yellow connectors. These can be connected directly to the corresponding inputs on the TV or you can connect them to the SCART adaptor and then connect that to a SCART input on the TV. Try using the red, white & yellow leads directly if possible, just in case the scart converter is faulty. If you have more than one set of RWY connectors on your TV then make sure you are using the correct set (you might connect the yellow video to one set and accidentally connect the red & white audio to another set). If you are using the SCART input then try swapping to another input if possible.
Make sure the all the connections are fully pushed into the Wii and the TV.
Feb 16, 2011 | Nintendo Wii Console
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Nintendo Wii Console Logo
398 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
