Question about Sony Playstation 3 (PS3) Console
Console not switching on - Sony Playstation 3 (PS3) Console
My ps3 turns on for about 3 seconds then shuts back down n red light comes on NOT YELLOW
Posted on Mar 16, 2011
How to manage Ericsson T720G switch?
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id johnwalker800969@gmail.com
Aug 18, 2016 | Computers & Internet
What Are Similarities and Differences Between Console and Mini USB Interfaces?
A console interface can be connected to an operation terminal for onsite configuration. It must be used with a console cable. After a switch is powered on for the first time, you need to log in to the switch through the console interface to configure the switch.
A Mini USB interface is also used to connect the switch to an operation terminal. The Mini USB and console interfaces on a switch are multiplexed and enable connection to the switch through different types of physical interfaces. Only one of the Mini USB and console interfaces can be used at a time. The Mini USB interface is preferred.
Apr 21, 2016 | Computers & Internet
Rear vent controls not working
The rear blower motor switch and the rear floor console switch bezel are serviced only as an assembly.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the rear floor console.
Rear Blower Motor Switch
  1. Remove the rear floor console switch bezel by releasing the retaining tab located at each end of the switch bezel and pushing it out through the front surface of the console.
  2. Disconnect the wire harness connectors from the rear blower motor switch and the rear heated seat switches.
  3. Remove the rear heated seat switches from the rear floor console switch bezel by gently prying the switches free from the back of the switch bezel.
INSTALLATION
  1. Install the rear heated seat switches into the back of the rear floor console switch bezel. Make sure that the switch retaining tabs are fully engaged to the bezel.
  2. Connect the wire harness connectors to the rear blower motor switch and the rear heated seat switches.
  3. Install the rear floor console switch bezel into the rear floor console by pushing it in through the front surface of the console. Make sure that the bezel retaining tabs are fully engaged to the console.
  4. Install the rear floor console.
  5. Reconnect the negative battery cable.
Feb 20, 2014 | Chrysler Pacifica Cars & Trucks
How do I replace the lid switch on my Kenmore Series 80 washing machine I have the part
Hi
To replace the lid switch in a Whirlpool-built direct drive washer you’ll need to open it up. This washer use plastic end caps to cover the console screws. Just remove the console end caps and the console retaining screws are right there. Once you've removed the console screws, flip the entire control console up and back to reveal the cabinet retaining braces. After the cabinet is pulled back from washer you’ll be able to see the lid switch. You can inspect whether the lid switch is disconnected or burnt, use a multimeter to check the continuity of the lid switch.
Please post back for any further assistance.
Daniel
Jul 30, 2010 | Washing Machines
Create program for A-D:
A.) If else statement using Javascript
<script type="text/javascript">
//If the time is less than 10, you will get a "Good morning" greeting.
//Otherwise you will get a "Good day" greeting.
var d = new Date();
var time = d.getHours();
if (time < 10)
document.write("Good morning!");
else
document.write("Good day!");
</script>
B.) Switch Case Statement Using C#
using System;
class SwitchSelect
public static void Main()
string myInput;
int myInt;
begin:
Console.Write("Please enter a number between 1 and 10: ");
myInput = Console.ReadLine();
myInt = Int32.Parse(myInput);
// switch with integer type
switch (myInt)
case 1:
Console.WriteLine("Your number is {0}.", myInt);
break;
case 2:
break;
case 3:
break;
default:
Console.WriteLine("Your number {0} is not between 1 and 3.", myInt);
break;
decide:
Console.Write("Type \"continue\" to go on or \"quit\" to stop: ");
// switch with string type
switch (myInput)
case "continue":
goto begin;
case "quit":
Console.WriteLine("Bye.");
break;
default:
Console.WriteLine("Your input {0} is incorrect.", myInput);
goto decide;
C. For Loop Statement using C++
for(i=10; i > -1; i--)
if(i == 0)
cout << "Blast Off!" << endl;
else
cout << i << endl;
D. While Loop Using Java
void main() {
int counter = 1;
while(counter < 5 )
printLine("counter is equal to " + counter);
counter = counter + 1 ;
printLine("Goodbye");
Mar 22, 2010 | Dell Vostro 220 Desktop Computer
Kenmore Model # 110.26842691 my Heavy Duty Wash setting is not working.. is it a bad switch
The cycle switch is faulty or the Heavy Duty Wash terminal connection is loose. Check it first before ordering a replacement part.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The console is held to the cabinet by two screws hidden under the console end cap trims. Remove the end cap trims to access the screws by pulling or prying its top off the console.
Remove the screws at the front bottom corners of the console. Once the screws are removed, slightly pull the console to the front then flip it to the rear of the washer to access the switch.
Check the switch for any physical damage. Disconnect the wiring harness from the switch terminals and clean both the terminals and the connector. Reseat the connector several times to ensure good connections.
Replace the switch (part #3949181) when damage is found or when cleaning and reseating the connectors do not resolve the problem.
Pull the knob off the switch shaft and release the switch from the console. Install the new switch in place and insert the knob to the switch shaft.
Flip the console back to the top of the cabinet and align the tabs in the console end caps with the slots on the cabinet. Insert the tabs into the slots and secure the console to the cabinet with the two screws previously removed.
Mar 20, 2010 | Washing Machines
Need instructions on how to remove center console to access electric window switch.
Here is what I could find, hope it helps.
Good luck.
Regards,
REMOVAL & INSTALLATION
See Figures 1 and 2
The following procedure is a general procedure for console removal. You may have to modify or skip certain steps depending upon your vehicle.
  1. Disconnect the negative battery cable.
  2. Remove the shift knob, floor compartment door and console trim plate.
  3. Remove the instrument panel accessory trim plate.
  4. Unfasten the retaining bolts, detach the connector, then remove the console door.
0900c152800900b7.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Remove the retainers, unplug the connector, then remove the console door
  1. Remove the seats, as outlined later in this section, in order to get to the lower rear screw(s) on the side trim panels.
  2. Remove the console side trim panels.
  3. If equipped, remove the switch pack housing with the switches.
  4. Remove the console compartment floor protector, bolt covers and bolts.
  5. Unfasten the screws mounting the console to the instrument panel and tunnel.
  6. Unclip the harness and accessory plug.
  7. Tag and detach all necessary electrical connectors.
  8. If necessary, remove any remaining retainers.
  9. Tilt the rear of the console up, then slide the front tab back out of the instrument panel and remove the console from the vehicle.
0900c152800900b8.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Exploded view of a typical console mounting
To install:
  1. Position the console in the vehicle by placing the front tab of the console into the instrument panel slot, making sure to align the screw holes.
  2. Attach the electrical connectors as tagged during removal.
  3. The remaining of installation is the reverse of the removal procedure. Tighten the console retaining screws to 89 inch lbs. (10 Nm).
May 04, 2009 | 1986 Chevrolet Corvette
Cisco catalyst 3500xl (24 port) bad console
It is possible that your console port is configured for a different baud rate. Try to change your baud rate on your hyper terminal going from 115200 down to 2400. If it doesn't work you might have a problem with 232 driver chip that is located on the board next to your console port. You will not be able to find a schematics for this switch, it is not available for the public.
You can send this switch to me. I will glad to fix it for you.
Good luck.
336-416-1802
NetSalem
Jul 05, 2008 | Cisco Catalyst 2924-XL Enterprise Edition...
Connecting to console
The proper way to console to a switch (at least as far as Cisco Catalyst Switches are concerned) is a rollover cable and a DB9 adapter... I then use HyperTerminal to connect..
What type of switch are you connecting to, and what kind of hardware are you using?
I always use Cisco for networking (Cisco is the king of switches and routers).. here is their step by step for connecting to one of their swtiches:
http://tinyurl.com/b4o0
DG
Dec 25, 2007 | HP ProCurve 2524 24x10/100 Mbps Networking...
Sony Playstation 3 (PS3) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
