NEON "NE 1300" hangs after power on and displays "WAIT"
After power on my NEON "NE 1300" Stereo CD/Radio/Amplifier hangs and displays "WAIT". The "WAIT" used to go away after a few seconds. But now it stays there 'forever' and keeps me from playing a CD or radio.
Does anybody have an idea, what it is waiting for? What can I do?
Fuses are ok. All voltages output by the power supply seem ok (match the labels).
silly girl
  • 513 Answers
SOURCE: JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Posted on Jan 24, 2006
simplemitch
  • 752 Answers
SOURCE: PIONEER DC-Z92 CASSETTE DECK AMPLIFIER
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
bluegreenash
  • 661 Answers
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Posted on Oct 15, 2007
  • 4234 Answers
SOURCE: radio does not work
If the unit is only a few months old, returnit for warranty repair or exchange. A power fail should not effect it. Try unplugging it for a few hours to force a system reset. If that fails to resolve the problem, have it serviced under warranty.
Dan
Posted on Jun 04, 2008
  • 3 Answers
SOURCE: can't do anything - LCD screen says "PROTECT"
It may be that there is a problem with a fuse inside the stereo. It may say protect because the fuse has broken a connection that allows it to turn on. If the protect goe sup it is trying to help save the stereo from cooking its self, and give you a chance to get it fixed. If that is not the problem then it may be easier to just buy a new one, because a fix may be expensive if you don't have any warranties.
Posted on Jul 14, 2008
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
My radio works but when i put on the cd changer it plays but no sound
Are you using an amplifier? If you are, it sounds like you are using the power antenna remote turn on (usually blue) instead of the amplifier remote turn on (usually blue/white). Leaving tuner mode when using the power antenna remote turn on turns the amplifier off.
Feb 21, 2013 | Car Audio & Video
Since I purchased my 2009 dodge journey I have had an issue with my radio/cd player ... sporadically the volume goes out, if I turn it off, and on it comes right back on, but will only stay on for 20...
AUDIO Any diagnosis of the Audio system should begin with the use of the scan tool. For information on the use of the scan tool, refer to the appropriate Diagnostic Service information.
For complete circuit diagrams, refer to the appropriate wiring information.
AUDIO SYSTEM DIAGNOSIS
CONDITION
POSSIBLE CAUSES
CORRECTION
NO AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Amplifier fuse faulty, if equipped. 1. Check and replace fuses, if required. 2. Wiring to amplifier faulty, if equipped. 2. Verify radio on/off input to amplifier and verify battery and ground connections. Repair wiring as necessary. 3. Radio faulty. 3. Refer to appropriate Diagnostic Service Manual. 4. Amplifier faulty, if equipped. 4. Replace amplifier. NO AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speaker(s) faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty.
5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Power/ground wiring to amplifier open or shorted. 1. Repair wiring as necessary. 2. Power/ground wiring open or shorted. 2. Repair wiring as necessary. 3. Amplifier faulty. 3. Replace amplifier. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speakers faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty. 5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. SOUND DISTORTION (VIBRATION FROM SPEAKER AREA, BUZZING - HUMMING) 1. Door trim panel loose or missing fasteners. 1. Inspect door trim panel and correct as necessary. Replace any missing fasteners. 2. Water shield loose or misaligned. 2. Inspect water shield and adjust as required. 3. Items placed in door trim panel map pockets vibrating or moving from side to side. 3. Remove items from door trim panel. Ensure that vibration is no longer present. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE OPERATIONAL 1. Radio faulty. 1. Refer to appropriate Diagnostic Service Manual. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE NOT OPERATIONAL 1. Fuse faulty. 1. Check radio fuse and Ignition-Off Draw (IOD) fuse in Junction Block (JB). Replace fuses, if required. 2. Radio connector faulty. 2. Check for loose or corroded radio connector. Repair, if required. POOR RADIO RECEPTION WITH KEY IN ACCESSORY OR IGNITION ON POSITION 1. Antenna faulty. 1. Replace the antenna. 2. Radio ground faulty. 2. Check for continuity between radio chassis and a known good ground. There should be continuity. Repair ground, if required. 3. Radio noise suppression faulty. 3. Repair or replace ground strap as necessary. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. 5. Faulty rear window defogger. 5. Verify that the rear defogger grid is functioning properly, repair as necessary (Refer to 08 - Electrical/Heated Glass - Diagnosis and Testing). NO COMPACT DISC OR DVD OPERATION 1. Faulty CD/DVD. 1. Insert known good CD/DVD and test operation. 2. Foreign material on CD/DVD. 2. Clean CD/DVD and test operation. 3. Condensation on CD/DVD or optics. 3. Allow temperature of vehicle interior to stabilize and test operation. 4. Faulty CD/DVD player. 4. Refer to appropriate Diagnostic Service Manual.
Nov 01, 2017 | 2009 Dodge Journey
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
Installed sony stereo in 2001 dodge ram
are you running an amplifier off the deck? it may be that you are turning the amplifier on with the power antenna wire instead of the amp turn on lead. so when you go from tuner to cd the amp turns off.
Jun 06, 2009 | Car Audio & Video
Stereo radio not working
Being a Lexus , it might have an amplifier that is not geting power
May 03, 2009 | Lexus ES 300 Cars & Trucks
Sound
You are using an amplifier in this vehicle. There are two "Blue" wires on the back of the stereo. One, antenna, supplies power to the power antenna during radio mode only and the AMP trigger supplying power to the amplifier in every mode. You chose the antenna wire to power your amplifier.
Nov 03, 2008 | Kenwood eXcelon KDC-X559 CD Player
Stock radio stopped working
Have you checked the fuses. Usually under the dash or in the glove box.
Aug 14, 2008 | 2001 Dodge Neon
421 people viewed this question
 Grubhead
Grubhead
