How do i connect areil lead to outside ariel - Televison & Video
  • 604 Answers
You don't say what kind of wire you are using. If using coax, just screw the coax connector onto the back of the set, the other end should fasten to the connector on your outside antenna, If you are using 300 ohm wire, then you need to purchase an adapter that goes from 300 ohm to coax connector (these are called balun connectors) you can get one at radio shack..
Posted on Mar 16, 2011
Tip
How to change a broken electric ariel on a saab
my electric Ariel stopped working and I was quoted £87 to replace it I bought a replacement on ebay for £13 its a simple fix just undo the Ariel nut on top of the car rear wing get someone to sit in car and push radio button old ariel starts to come out simple assist it until it has completely come away from car put new lead into hole then get person in car to switch of radio and feel the ariel start to be pulled back into place be carful to keep it straight as it enters then replace locking nut total time less than 5 mins cost £13 plus one person to assist easy fix
on May 07, 2015 | Saab 9 Cars & Trucks
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
I have a soniq tv and all of a sudden the picture just started cutting in and out, I thought it was the reception from the Ariel so I turned it off for a bit turned it back on and there was no picture
1. Check the connections for tightness on the input wires going into the TV. If this doesn't fix it, check that the cable going in connections are secure on the wire.
2. Check the connection outside on the ariel, this might have loosened or froze loose with ice and wind..
Jan 18, 2013 | Televison & Video
Sharp TU-TV322H failing to make planned recordings
I had this problem aswell! I tried everything but ended up phoneing the help line, when they asked for what frequancies they found out i was picking up different ones form two different stations. I took the ariel out of the back on the freeview box and run a scan for channels (of course it came up with none as the ariel is unpluged but it overwirites and clears the incorect frequencies). Then plug the areil back into the freeview box and run a scan for channels. After doing this i picked up the correct frequencines form the correct station and my recordings actually recorded! If you phone the help line (08444159159) they will tell you what frequencies you should be picking up. I hope this qorkes for you!
Apr 05, 2010 | Sharp TUTV322H
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Can see no way of connection to terrestrial TV, no scart connection?
easy dose it have rf out? or phono out if you have phono out buy a phono to scart lead to conect
Apr 28, 2009 | Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
Televison & Video Logo
Top Televison & Video Experts
