Question about Microwave Ovens
My indesit 1570c wont heat up just wondered if it had a reset button? thanks
  • Microwave Ovens Master
  • 6,771 Answers
If all other areas are working, but won't heat, the most likely problem is the magnetron not working. There are two additional parts that will cause same issues, the high voltage capacitor and diode. Chances are the repairs will not be cost effective but cheaper to replace the microwave oven.
Posted on Mar 16, 2011
My Frigidaire microwave model PLMV169DCB turn table stop working & wont heat up
Thank you for your inquiry, Justin!
From the information you have provided your Frigidaire microwave is not turning and it has stopped heating up. It sounds like the motor, magnetron, or control panel may need to be replaced inside of your microwave. This could also be a miscommunication within your microwave and a reset could help clear it out. You can reset your microwave by flipping the household circuit breaker off for at least ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Microwave Ovens
Wont heat food up
the magnatron is probably burnt up...
how old is the unit?
what brand and model is it?
Mar 24, 2013 | Microwave Ovens
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Unit was working than just shut down, the display went dead.
hello,
the solutionhas noting to do with reset button or code
what the problem is from the element (heat provider)it is always is silver colour all it means is there is disconnection from it or it is bad.
what you need to do to fix up your oven is to unscrew it and then trace down the wire to the heater (element) but if you did not see any sign of disconnection then you will have to make a change of the element it mean bad .
thank you and thanks for using fixya.
Jun 01, 2010 | Sharp KB-6015K 1000 Watts Convection /...
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Microwave is dead. wont lite up. Power source is fine.
We have a similar situation where we were heating food, there is no power. The model #JVM1090 Serial # 912305S. Is there a fuse or reset button, we do have the owner's manual and would like to make the repair if it is simple.
Thank you for your help
Joe Spano
Nov 25, 2008 | GE Microwave Ovens
Microwave Ovens Logo
139 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
