Question about D-Link (DES-3350SR) (851210) Networking Switch
Hi all i hv configured dlink switch DES 3350sr with user name and password. i saved. but now problem is that when i reboot this i can not login with that user name and password. so after all problem is that i'm not able to login that switch.
  • 604 Answers
Evidently your sign in name and password were not saved. If you remember the old password and name try that. IF not, thenn find the reset switch, press it and start fresh with factory defaults
Posted on Mar 16, 2011
No Bull I bougth a DES-3350SR D-link I need to reset the password.
http://www.helpowl.com/p/D-Link/3350SR/Research/20945?search=des%203350sr%20setup
DES-3350SR Layer 3 Fast Ethernet Switch Users Guide reset Restrictions Only administrator-level users can issue this command. Example Usage:
To restore all of the switchs parameters to their default values: local>reset config Command: reset config Success. local> login Purpose Syntax Description Used to log in a user to the switchs console. login
This command is used to initiate the login procedure.
The user will be prompted for his Username and Password. none. none. Parameters Restrictions Example Usage: 46
hope this helps
Jul 07, 2012 | D-Link (DES-3350SR) (851210) Networking...
How to recover password for Dlink DES-3350SR
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Aug 04, 2011 | D-Link (DES-3350SR) (851210) Networking...
I wanna password reset my D-link 3624i switch...can anyone help?
Recovering a Lost Password - If the password for the router configuration is lost then the
following procedure can be used to set it to "friend".
1) Power cycle the router
2) Hold down the "s" key during startup. (The router will startup with the
current release but no configuration
3) Edit the configuration file and remove the line (Ctrl Y):
set user=manager pass=3af00c6cad11f7ab5db4467b66ce503eff priv=manager
4) Save the router configuration
5) "restart reboot"
Feb 25, 2011 | D-Link DES-3624I 20 Port (DES-5220TF DEMO)...
I want to configure des 3026
hi,
in the web browser type 192.168.1.1 and enter password and login name as"admin" ( or if you have change login and password then enter that) and you will get the configuration page...
Hope this has helped you.. Thanks...
Jul 14, 2010 | D-Link Dlink DES-3028P Switch 24-port...
I have forgot the password their is no reset bu...
Dlink has stopped production and support on that particular product. Really need to dive in self and figureout resetting and configuration
This looks it can be done from console.
To go into console you need console cable connected to your switch and computer.
Start hyper terminal, by going to start-run- type "hypertrm" hit enter.
For more information refer to below manual
http://www.cybernates.com/des3326sr.pdf
User manual for your reference
ftp://ftp.dlink.com/Switch/des3326SRM/Manual/des3326SRM_Manual_402B13.zip
Hope this helps.
May 21, 2010 | D-Link DES 3326 (DES-3326) Networking...
I want the default ip address, domain name and password of "dlink des 1024d switch"
Hi,You can get your expected domain name also getting hosting at just $1.99 per year from this http://www.tucktail.com/ site ,visit here for more details.All the best.
May 11, 2010 | D-Link DES-1024D Express EtherNetwork...
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Username and password forD-Link DES-1008D
hello, no user name or password for dlink hub. the only thing i can help you with is default IP address for your computer(server) which is
IP:192.168.0.1
subnet:255.255.255.0
Dec 20, 2008 | D-Link DES-1008D 8-Port Ethernet Switch...
Configration
Here is the link to download the user guide (it thoroughly covers configuration) for you Dlink DES 3225G Layer 2 24 port switch in .pdf format (you'll need Adobe reader to use it, and you can download a free version at Adobe's site if you don't have it): Here's the link: http://www.its.bth.se/courses/etc001/DES3225G.pdf
Good Luck.
Feb 25, 2008 | D-Link DES 3225G Networking Switch
Configurtion
Hi prasad, Here you go: ftp://ftp.dlink.com/Switch/des3226/Manual/DES-3226_MIB_manual_170.zip All support info and downloads for that switch can be found here: http://support.dlink.com/products/view.asp?productid=DES%2D3226# Hope that was fast enough for you!!! Good Luck, El Duderino
Nov 17, 2006 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
D-Link (DES-3350SR) (851210) Networking Switch Logo
197 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
