Question about Panasonic KX-P2023 Matrix Printer
I am using Sage to print invoices, i installed a dot matrix printer to do this. The model is Panasonic KX-P2023. The problem is when i print an invoice, the invoice for some reason keeps printing the totals etc on the second page. I have went into the printer properties and changed the preferences for paper size to lots of different sizes however it continually prints onto the second page.
3 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: Unable to custom select paper size of 8.5in x 7in
Ouch. You're going to have to emulate an Epson LQ-850 or Proprinter X24 so you can send the proper page length command (Esc "C" 07 or 42). I assume you have a magic USB to Parallel cable and you're going to have to do this only the first time you send the setup string to the printer.
Best I can do, since I'm not familiar how Simply Accounting sets the printer up.
Carl
Posted on Jun 20, 2011
krb55
  • 604 Answers
SOURCE: I am using Sage to
you need to change the paper size or font size in the software that creates the printout. if you can, do a print preview before you print to see if its going to try and print to one page
Posted on Mar 16, 2011
I am using Sage to print invoices, i installed a dot matrix printer to do this. The model is Panasonic KX-P2023. The problem is when i print an invoice, the invoice for some reason keeps printing the...
Mar 16, 2011 | Office Equipment & Supplies
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
SECOND INVOICE PRINTING HALF WAY DOWN THE PAGE?
It sounds like you have the paper size set to letter instead of the size required for your invoice
Aug 03, 2009 | Panasonic KX-P2023 Matrix Printer
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Jul 30, 2009 | Panasonic KX-P2023 Matrix Printer
Prints one line per page
check your printer settings. go to preview print page before printing. Might have to uninstall printer and reinstall it again. Hope that helps You.
May 24, 2009 | Panasonic KX-P2023 Matrix Printer
Kx-p2023 vibration
You probably have a power supply problem and searching for the failed part requires some knowledge and a couple pieces of test equipment.
The vibration is liekly caused because a DC voltage produced inside has AC ripple on it because of a failed part, probably a bad capacitor.
Apr 21, 2008 | Panasonic KX-P2023 Matrix Printer
hai
apply some oil to the rod . keep the head postion in the last. Try to print with out the ribbon catriage
thank u
Feb 04, 2008 | Panasonic KX-P2023 Matrix Printer
Panasonic kx p2023 with a Mac system os x10.39
When you add the printer in Mac select Epson LQ850 driver or install the Generic Text driver. That is your most basic driver for all operating systems
Nov 08, 2007 | Panasonic KX-P2023 Matrix Printer
Tear off
First, if you have your manual, look it at for possible solution. Does this printer have a "load" or "top of form" function? There may be a "programmable" setting which will back the paper back down to the correct spot. The college where I'm employed used to have several Panasonic dot matrix printers, but almost all are now long gone.
Sep 18, 2007 | Panasonic KX-P1150 Matrix Printer
Panasonic KX-P2023 Matrix Printer Logo
70 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
