Question about Kodak EasyShare One Digital Camera
Camerta droppes in a pail of water - Kodak EasyShare One Digital Camera
  • 604 Answers
You have most likely distroyed your camera, it may be too late to fix this, but take the back off the camera, take batteries out and anything else that can come out (SD Card). let the cam sit in the sun or take a hair dryer on low heat and blow into the camera, if you can dry it out it may work again, but this fix is only good if you do it right after the accident, but its worth a try
Posted on Mar 16, 2011
  • 20 Answers
First remove the battery & don
Lg wf-t9230tp is not pumping
Open small door at bottom front of washer. get a pail and put small black hose in pail and remove plug. After machine is drained remove large screw cap. probably a sock or something in trap remove and put back in place.
Apr 23, 2014 | Washing Machines
Water run real slow not enough ice
Start with replacing your water filter, Frigidaire water filters tend to reach their life's end much sooner than others, regardless if you have a filter reminder light, your filter can get dirtier faster depending on your water quality, the reminder light on the front dispenser is simply a timer and has no idea how dirty your water is. By pass plugs are also avail to take the place of water filters. In addition to the water filter, it is advised to check your water pressure at the back of the unit. turn the water at the shutoff, unscrew the connecting hose at the back of the fridge, place the hose in a wash pail, or medium sized trash can and turn the water back on, your water should rush out fairly strong causing some splashing in the pail. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS3R5EMB Side by Side...
How to defrost a turkey properly
Leave it in the fridge for 3 1/2 to 4 days to thaw Make sure to have a place to catch the muscle fluid. To thaw the turkey in an unorthodox way place it in a 5 gallon pail and place in a bathtub or shower with a hose running lukewarm water and have it overflow. I put a piece of garden hose where the shower-head goes clamped to the pipe and drop it in the pail run for 3 hours
Nov 28, 2013 | Refrigerators
How to defrost a frozen turkey
I use a 5 gallon pail and place it in a shower with a hose in it running warm water and overflowing the pail it takes 3 hours
How to thaw turkey quickly
I put it in a 5 gallon pail and set it in a bathtub or shower area with a hose filling the pail and overflowing. I use warm water takes about 3 hours
Nov 27, 2013 | Refrigerators
How to defrost a fully cooked smoked frozen turkey
if it is in a waterproof bag put it in a 5 gallon pail place the pail in a spot that you can overflow it and put a hose in it running warm water I did that last year and it thawed in 3 hours
6.0 hp 12 Gallon Shop-Vac 'exploding'
Those type of vacuums are designed for light duty work around homes anyways. For commercial industrial work as you are doing you need a sump pump. We used to drop one in a 5 gallon (20 liter) pail, drill holes in the pail and suspend from a rope. (you can put screen around the pail covering the holes if needed too). Use a stiff hose to expell the water. You can change to a flat hose like a pool waste water hose or fire hose after the water is out of the trench.
Nov 20, 2013 | Shop Vac Vacuums
Drain not working
yes there is. get a container of limeaway and follow the directioins.
Jul 18, 2008 | Danby DDR586R Dehumidifier
Will only start water when in wash cycle
  • The diaper pail we suggest using is the size medium Diaper Pail with Carbon Filter, or, if you want a really big pail, the American Diaper Association approved 54 QT Diaper Pail. We sell them at Diaper Safari! They are nice and big andboth have a slot for a Citrus Circle which helps eliminate odors.
  • Try using a mild and environmentally safe detergent like: Bi-O-Kleen, Allen' Naturally or ECOS. You can also use Arm & Hammer for sensitve skin or Sensi Clean - do not use Dreft!
  • A Citrus Circle or a little baking soda some tee tree oil in the bottom of the diaper pail liner will help against odors.
  • Diaper Pail Liners can be our re-usable waterproof pail liners or standard 13-gallon kitchen trash bags.
  • Sprinkle a few drops of BacOut Stain & Odor Eliminator on the diaper if "poop" got onto the diaper itself.
  • Adding a few drops of Tee Tree oil to the main wash leaves diapers smelling fresh and kills bacteria - not for pocket diapers.
  • Sun-dried diapers and covers become snow-white. Try this as often as the weather allows.
  • Use the dryer for a few minutes to soften sun-dried diapers that get stiff.
  • Wash and dry new diapers one to five times before wearing - for unbleached diapers this will remove the natural waxes and will fluff up the cotton, which gives the diapers their absorbency. You will only need to wash the covers, Fuzzi Bunz and AIO once or twice at the most.
  • Spray any solids off with the Mini Shower - it makes makes cleaning cloth diapers very easy
  • Don't let wet and clean diapers sit in the machine overnight.
  • For serious stain you can try something like Spay and Wash.
Feb 18, 2008 | KitchenAid KAWS700L Top Load Washer
Leaking water
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
Jul 17, 2007 | Maytag M7DH45B2A Dehumidifier
Kodak EasyShare One Digital Camera Logo
15 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
