Question about GE Refrigerators
My GE frig. the wate constantly runs thur the ice maker. I replace the water valve but it won't stop. Something is keeping the valve open.
  • 604 Answers
There is a sensor, usually a copper tube that sits in the water. If it has gotten bent or is somehow not in the right position, the sensor says you need water, find that sensor and either replace it if its bad or put it back where it belongs to sense when the proper water level has been reached
Posted on Mar 16, 2011
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker stopped making ice
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
May 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped making ice...no water coming into maker nor does the unit appear to be rotating...water dispenser works fine.
Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
May 28, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
Ice maker quit working on GE refrigerator
Sometimes on a ice maker what will happen is the water line that fills the ice maker will freeze. You can use a large syringe filled with hot water and from the rear of the frig remove the water line where the hose goes into the rear of the frig and force some hot water into the tube to see if it is clear.
If the line is clear fill the ice maker manually and see if it goes through a cycle.
If it goes through a cycle you have to check to see if the ice maker is calling for water by putting a multi meter across the contacts of the water inlet valve located behind the panel on the back of the frig. Advance the ice maker to run through a cycle and see if it is calling for water. If you have current going to the valve and no water momming in, replace the valve.
If you do not have current going to the valve after the ice maker has gone through a cycle. Replace the ice maker.
Dec 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I just hooked up the water supply line for the ice maker and water. Water is continously running from the water dispenser. Pushed the lever thinking maybe it is stuck. Nope. Doesnt stop..
Is this a new or used refrigerator?
There appears to be a double water valve located on the bottom of the fridge. One of them is either clogged open, or there is something on the door lever which is keeping the water switch constantly enabled.
Dec 16, 2009 | GE GSH22JFR Side by Side Refrigerator
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
My ice maker is pooring out water. How do you stop the water from pooring out?
unplug frig,if water still come's in than you have a bad inlet valve and nead to turn water off.if water doe's not come in than you nead to unplug ice maker and plug frig back in.if no water come's in than you have a bad ice maker.in most case's you are better off buying a new ice maker.
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker over flow now water wont fill back up
no its not blown up low water pressure will cause also sticking water valves if it has worked properly for a while then change the water valves
Jan 29, 2009 | Maytag MSD2732GR Side by Side Refrigerator
GE Profile refrigerator ice maker stopped working
I had the same problem where one of the solinoids in the valve- the one controlling water to the ice machine had stopped working. A good test is to pour water into where the ice cubes are made. If ice cubes come out then the problem is most likely in the valve. I replaced my valve for the second time in 8 years today and the ice is comming out nicely.
May 17, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
