Question about Samsung SF650 Plain Paper Laser Fax
We are sending faxes on yellow paper and the fax machines recieving the fax are reversing the colours (its printing white text onto a black background). It must be something to do with the settings on our SF-650 as all the recieving fax machines are printing it incorrectly. Thank you for your help.
  • 114 Answers
Change the paper to white and see if it's working, because sometimes any other colour than white as background can be transmitted as gray or black.
Posted on Mar 16, 2011
  • emma_harvey Mar 16, 2011
    It works using white paper - we need to use yellow.
  • garsonfixya Mar 16, 2011
    Sorry, but you will end up the same ...with any other color, including yellow. Try a very pale yellow.
  • 604 Answers
Stop using yellow paper, problem solved
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Want to change it to black and white printing only.
A manual for your fax is available here, and will show you how to set your fax to monochrome mode.
Apr 14, 2008 | Brother PPF-1820C Plain Paper Inkjet Fax
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
Apr 26, 2010 | Canon FaxPhone L75 Plain Paper Laser
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
1840C Brother fax machine
Do you have ink / toner / paper?
Unplug the power cord for 10 seconds.
Sep 08, 2008 | Brother IntelliFAX 1840C Plain Paper...
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Can recieve well, sends all black
The scanner is not receiving light. That is either because paper is covering the scanner, or the scanner light source is not working. In this case, make sure the connections are in place, if so, replace the scanner.
Feb 26, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Ink cartridges, recieving fax
It sound like your machine is receiving but as soon as it tries to prints the fax it has this problem.
Rewind the ink ribbon so it is nice and tight in the housing. Clean the black roller above it with some cleaning alcohol or equivalent (nothing too harsh).
See how that goes if you are still having problems replace the whole cartridge (not the refills) PC-401.
Feb 19, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax does not want to print
No the machine uses some of the colour ink when printing faxes, mostly cyan.
Apr 23, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Samsung SF650 Plain Paper Laser Fax Logo
215 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
