My laptop is not able to transmit you tube , I think it is to do something with the configuarations. Kindly help
  • 28 Answers
When you say unable to transmit, you mean unable to play? I would update your adobe flash. I had the same problem and it worked. Good Luck!
Posted on Mar 16, 2011
Cobra 148 gtl d has problem transmiting with covers off. trying to tune radio up. was thinking I need to ground the chasis
I would say a bad or cold solder joint on board somewhere. Bad quality control. Might flex radio chassis slightly while keying? A tooth pick and hours of probing around switching area on board and the pa section till problem found.
Oct 25, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
My extension tubes were put in incorrectly and I can;t unstick them. Suction is not great think something is stuck in tube.
Hello There! I had the same exact problem. Seems something was wrong or stuck in the tubes.
Finally, when I kept trying to clean it out, the tube ripped off and I found a clog of dust in it. So, try getting replacement tubes & it'll work for sure!
I wish I helped you! Let me know if you need anymore help! Don't forget to rate! :)
Jan 14, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
Hey i have a acer notbook pc zg5, i have all power but no screen can anyone help?? cheers
Try plugging in a normal monitor in the back make sure that the monitor in on standby then when the laptop starts it should send a signal on the 15 pin HD VGA lead if the screen button goes green then it should work the monitor.
You will then know if the internals of the laptop are working fine or not, if it works in this configuaration then I am afraid that you will need a new LCD screen for your notebook. These can be found on e-bay but they can cost upto £50 and are difficult to fit unless you have experience.
Oct 13, 2009 | Acer Aspire 3680 Laptop
S Meter takes a reverse deflection when transmit is OK on receive
what does rx mean on the cb and it makes alot of nois
Jan 14, 2009 | Radio Communications
I HAVE INSTALLED THE LEXMARK 4200 SERIES PROGRAM ON MY COMPUTER THE LEXMARK IS A X4270 MODEL. BUT I AM UNABLE TO PRINT MATERIAL FROM THE COMPUTER TO THE ALL IN ONE LEXMARK OFFLINE OR ONLINE. IS THERE...
START- CONTROL PANEL-PRINTER AND FAXS.
Is it listed there? If not click on ADD A PRINTER, follow the prompts. if that doesn't work , let me know, and we'll try other things. .
Dec 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Laptop to tv
No what is happening is your laptop is seeing the TV as a secondary display and all your icons are on the primary (laptop) display. While pushing the Fn key, press the key that will redirect output from your laptop screen to the external screen. There should be a picture of a monitor in blue above one of the F keys or something. This will redirect the output to the TV as a primary display. And if you could kindly rate this solution with a fixya rating, I'd appreciate it :c) Thanks!
Dec 29, 2008 | Dell Latitude C400 Notebook
Compaq armada m700 wont power up all the way
Sounds like you may have a problem with the internal power supply box? I am not sure but that may be at least something for you to have checked out. If the fan is not spinning this is usually a sign this may be what the problem is. GOOD LUCK!
May 13, 2008 | Compaq Armada M700 Notebook
Monitor turns off
sir\maam i think there something wrong with the power supply of your laptop,,tv kindly check the power supply section,,,hope to help you thnkzz??
Jan 29, 2008 | CTX S762A 17" LCD Monitor
Future CE-250 will not transmit anything, help!
I had same problem, the error message indicated that USB was not recognized by the program. I then tested with a spare cable, it worked. Therefore, the problem appeared due to a defected cable. Hope this helps.
Dec 29, 2007 | Singer CE-200 Quantum Futura Computerized...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
