How to remove the write protection in my usb flash drive?
  • 120 Answers
Please refer to this article usb remove write protect
Posted on Mar 16, 2011
    Scholar:
  • 72 Answers
Pull the USB flash drive out of your computer's USB port. Check the bottom end and sides of the drive to see if it has a write protection switch. Push the plastic switch into the "Unlock" position.
Insert the USB flash drive back into the USB port. Close the pop-up window that appears and navigate to the Start menu. Select "My Computer."
Locate the drive letter that corresponds to your USB flash drive in the "My Computer" window, such as "F:\" or "D:\." Double-click the drive letter. Attempt to use one of the files on the drive. Right-click one of the files if you still receive a write protection error and select "Properties."
Navigate to the "General" tab and remove the check mark from the box labeled "Read-Only." Click "Apply" and then attempt to use the file.
Return to the Start menu and click "Run." Type "Regedit" and press "Enter." Navigate to the registry folder "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies."
Check if there is an entry at the right side of the window labeled "WriteProtect." Right-click inside the window if the entry is not there and choose "New DWord." Type "WriteProtect" and press "Enter."
Double-click the "WriteProtect" entry. Check that the value listed in the text box is "0." If it is not, delete the value and replace it with "0."
Close the registry editor and attempt to use any of the files on the USB drive. Return to the "My Computer" window if you continue to receive a write protection error message.
Right-click the drive letter for the USB flash drive. Choose "Format." Click the drop-down menu named "File System" and select "Fat32."
Click "Start" to format the USB flash drive and remove the write-protection feature.
How to remove write protected on my 2.0 flash drive 64GB usb. I don't have a button on the side to disable it. Please help me.
Visit following link.. it will guide you how to remove write protection from USB.
http://www.pcadvisor.co.uk/how-to/storage/how-erase-write-protected-usb-drive-or-sd-card-summary-3633096/
May 14, 2016 | Electronics - Others
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How to remove usb write protection
Turn on your computer and plug in the drive after your operating system has loaded.
  • 2
    Open "My Computer" and search the list of drives until you find your USB drive letter.
  • 3
    Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
  • 4
    Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
  • 5
    Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
  • 6
    Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
  • Read more: How to Remove Write Protection From a USB Drive ' eHow.com http://www.ehow.com/how_4924168_remove-write-protection-usb-drive.html#ixzz1BY4ve3fh
    Jan 20, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
    WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
    Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
    http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
    Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    I cannot remove write protection of my transcend 4GB pen drive
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
    2. Format
    (Before removing USB flash drive click on the Safely Remove
    Hardware icon and then click on USB flash drive you want to remove)
    Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    DISK WRITE PROTECTED AND FILES CHANGED
    http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
    2. Format
    Oct 06, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
    USB flash drive write protection
    Most USB drives don't have a Write Protection switch, but if yours does, then move the slider.
    If it doesn't have a switch, the only way to use the drive is to format the drive. First, note the drive letter, such as E, F G for your drive. *** BE CAREFUL *** This will remove all files. Go to Windows Explorer, note the drive letter , Right-click and select Format. Again, BE CAREFUL not to format any other drive, just your removable USB drive.
    Hope this helps.
    Aug 10, 2009 | Electronics - Others
    I cannot copy files from computer to my phone memory card
    2. Format
    Mar 15, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
    Computers & Internet Logo
    301 people viewed this question
    David Payne
    David Payne
