Question about JBL Northridge E 250P Subwoofer
Hi, my E250P is experiencing blub, blub sound after 45 minutes to 1 hour in operation for the past few month. But at this point of time, when switch on, loud wobble sound are generated even the input source is disconnected..Which component need to be replaced as i don't have an oscilloscope to test at the test point.Pls assist me and thanking you in-advance.
    New Friend:
  • 60 Answers
WE REPAIR THESE AMPS ... JBL PB10, PB12 (IF SCREW NEAR ON/OFF SWITCH) WE REPAIR THE PS10, PS12, VENUE SUB12, TSS-1100 TSS-1200 E250P. CHECK FOR US ON EBAY EDWARDS ELECTRONICS OR MESASURPLUS.COM - FAST WORK - WITH WARRANTY - HAVE FIXED THOUSANDS OF THEM.
Posted on May 24, 2012
  • Michael Edwards
    Michael Edwards May 24, 2012
4 Suggested Answers
SOURCE: PB10 Loud Hum and Crackle- LED Lights mixed Red/Green
If you take all of the screws out of the panel where the inputs are you can get to the fuse. It is just above the power supply.
Posted on Jun 25, 2008
  • 175 Answers
SOURCE: Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
Posted on May 28, 2010
Testimonial: "Thanks for such a quick response. Good to get a second opinion. Much appreciated!"
idrvnsx2
  • 60 Answers
SOURCE: hi sub make funny noise
WE REPAIR THESE AMPS - EBAY - EDWARDS ELECTRONICS - :)
Posted on Jan 03, 2012
How Do I program the hpm digital time switch hl 03705 Eco Rex d11
How to Program HL 03705 EcoRex D11 Timer
The "switch" is a small rod which can be moved 5 ways - left, right, up, down and IN.
Before programming check that time and date are correct.
Time - push switch IN, then down once until TIME flashes on display. Push switch IN, then up or down continually to select hour, then switch IN, then up or down continually to select minute. Push switch IN to save.
Date - push switch IN, then down twice until DATE flashes on display. Push switch IN, then up or down continually to select year, then push switch IN, then up or down continually to select month, push switch IN, then up or down continually to select day. Push switch IN to save.
Programming - for the sake of this exercise the timer will be set to come ON at 7am and OFF at 10pm, 7 days of the week.
Note the numbers 1234567 printed just above the display window. These represent the days of the week, starting with Monday.
1. Push switch IN, then down four times until PROG flashes on display. Push switch IN. The display shows a vertical line with numbers, at the bottom of which is a digital time which should show 0:00. This is midnight, Sunday to Monday.
2. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Monday and will be the first ON time. (Push switch to the left to change minutes, each push advances time by 1 minute).
3. Now push switch to the right and HOLD there. BE PATIENT! It takes several seconds before the time changes, firstly a minute at a time, then in 15 minute blocks. Still holding the switch to the right watch the digital time display advance (don't look at the vertical line which has another thick line develop beside it as the time changes!) until it reaches 22:00, then release switch. This is the OFF time, 10pm Monday.
4. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Tuesday and will be the next ON time. (Push switch to the left to change minutes, each push advances time by 1 minute). Note that there is a small dot under the number 2 at the top of the display to indicate it is Tuesday.
5. Now push switch to the right and HOLD there. Still holding the switch to the right watch the digital time display advance until it reaches 22:00, then release switch. This is the next OFF time, 10pm Tuesday.
6. Continue the steps #2 and #3 through Wednesday to Sunday. You will know when you are back to Monday by looking at the dot at the top of the screen returning to be under the number 1, OR when you return to 7am Monday there will be a thickening of the vertical line starting at 7:00.
7. PUSH THE SWITCH IN TO SAVE THE PROGRAM.
Testing - To check the program settings - push switch IN, then down five times until TEST flashes on display. Push switch IN.
Each upward push of the switch moves the display through each subsequent ON and OFF change. Check the day for each ON and OFF by viewing the dot under the numbers 1234567. After the last ON/OFF change the display shows PROG END.
Operating the Program
Push switch IN, then down six times until AUTO flashes on display. Push switch IN. The device now operates on the times that were programmed. The display returns to the "home" view, showing the current time, also vertical strips lined up under the numbers 1234567, representing the times of operation each day.
Outside the display window, at the bottom of it, the words OFF and ON are printed to the left and right respectively. A cursor points to one of these to show the current status of the device.
To bypass the program - push switch IN, then down past AUTO until ON or the next one, OFF, flashes on display. Push switch IN - at ON to have device permanently switched on or at OFF for device permanently switched off.
Feb 04, 2015 | Hardware & Accessories
2008 GMC Envoy
this sounds like is a lost joint in the engine or a broken gear box
Jul 08, 2008 | 2008 GMC Envoy
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Jun 22, 2008 | Metz 45 CL-1 Flash
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
JBL Northridge E 250P Subwoofer Logo
334 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
