Question about D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter
Hello i have d'link airplus g dwl g630 e2 5.0 network card in my other laptop.. it has drivers installed and it connects to network, but i cant get in internet.. it says " the connection has limited or no connectivity" i has ip adress, but no dns, deafult gateway...
  • kooliksvajal Mar 16, 2011
    Thanks Geekman, but i tryed Repair... i also tryed cmd ipconfig/release, ipconfig/flushdns, ipconfig/renew...
    problem is still there..
    im pretty sure i got proper drivers since all works, connects well but it wont get deafult gateway...
  • D-Link Master
  • 32,281 Answers
This happens when the wireless network card fails to get an IP address from the wireless router.
To get the router to issue your wireless network card with a new IP address, right click on the wireless card icon on the task bar and click Repair.
Posted on Mar 16, 2011
  • Chris Hingee
    Chris Hingee Mar 18, 2011
    Try restoring the D-Link back to the factory defaults and then re-configure the D-Link.
    To reset the D-Link back to the default settings -
    Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button.
    Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link's configuration URL. OR open the browser on your laptop and enter the D-Link's configuration URL..http://192.168.0.1
    The default login = admin
    The default PW = blank (just press Enter)
    You can now configure the wireless settings.
  • kooliksvajal Mar 18, 2011
    Well the thing is my D-link is network card not a router... my router works very well. I got 3 laptops connected to that router and all of them work perfect. The laptop wich has d-link airplus G dwl 630 ver e card also has intel wierless card in it ( D-link networkcard is just an extra card) but intel wierless cart with is intergrated in computer aint working.. i added drivers to intel card but it connects to network and then disconnects right away..
    Is it possible that having 2 network cards disturb each other? meby if i swich out intel network card from bios and try use only d link card? because i allready tryed just intel network card without d link network card...
After running add hardware wiz on DWL-G630 wireless adapter, the message came out with hardware can not install CODE 10, I am not sure if this is the hardware problem or the driver issue, only one light...
Go to device manager and uninstall device. Then remove card.
Download driver from here http://www.dlink.com/products/?tab=3&pid=DWL-G630&rev=DWL-G630
after installing driver plug the card back in.
Feb 23, 2011 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
I have a dwl g630 wireless ccard 802.11g/2.4ghz and i cant find the software for it. when i put it into the laptop it dosent search the networks.
Hello
If you go to http://www.dlink.com/products/?pid=DWL-G630 and click "Support Resources" you'll find instructions on how to determine which version of DWL-G630 you have got. If you then click on the link for your version you will find a link for "Drivers" and you should find all the appropriate software available for the card.
Hope this helps :-)
Dec 06, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D link dwl g630 software
i think you can get the drivers from the Dlink website if that is indeed what your after
Why cant i connect my dlink
Forget the D-Link drivers!!! I suffered with this same DWL-G630 issue for two years, trying different settings, reloading drivers, all with no solution. My card kept dropping it's connection, or wouldn't connect at all until I removed then replaced the card. Finally, I read on another forum this card uses the same chipset as an ASUS card, and to try the ASUS drivers. I downloaded and manually installed the drivers from here:
ftp://ftp.asus.com.tw/pub/ASUS/lan/wifi-g/wifi-g.zip
Unzip it, but DON'T run the setup.exe file, because it will try to install the ASUS program. If you open the unzipped folder you will find another folder called "Drivers". Just use your Network Settings (from your Control Panels) to manually update the driver of your DLink card, and navigate to the Drivers folder just mentioned. Reboot -- you'll probably have to reconnect to your access point/router one last time, but that's it! It's good as gold after that.
I was used to losing connections 5-8 times PER DAY (I'm 15 feet from the router!) and now I've been connected non-stop for two weeks and counting!!
Mar 20, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
I just posted a question regarding a D-Link AirPlus G DWL-G630 wireless card I have plugged into the pcmcia slot in an older dell laptop. I have wireless service through Comcast. I can't connect to the...
so your saying that your using the pcmcia card on an older dell laptop. everything else works but that...
have you tried uninstalling the drivers and re-installing again? or maybe you need some updates on your D-Link wifi card.
older dell laptops usually have driver issues so be patient with that.
Jan 24, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Can't connect To internet w/ Wireless
try uninstalling it and re-installing it. the problem may be with its drivers.
Download driver
Please paste the following link into your browser's address bar and run the setup after unzipping the file downloaded and watch how all your problems vanish!
ftp://ftp.dlink.co.uk/wireless/dwl-g630/DWL-G630_driver_v5.11.zip
Oct 21, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Network card
i have D-link airplus G DWL-G630 wireless G notebook adapter i need driver wear i can get
Apr 07, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D-Link DWL-G630
You will need the driver for your DWL-G630. You may download it from D-Link's web site.
http://support.dlink.com/downloads/
Just download the driver and follow the Quick Install Guide on the web site.
Feb 12, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter Logo
215 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
