Question about Microsoft Windows XP Professional
WIndows XP blue screen
I got a blue screen saying there's a hardware malfunction. After rebooting, everything seems to be working fine. Is there a reason for worry?
  • Jay Harel
    Jay Harel Aug 01, 2008
    Is there anything else I can do short of reinstalling everything?
  • Jay Harel
    Jay Harel Aug 02, 2008
    Great solution!
  • 781 Answers
The blue screen lock up can be caused by conflicting programs if you have more than one in use at same time
try this Go to C:\ right click go to properties/tools/error checking/check now when new box pops up tick box to repair errors and reboot when windows reboots it will scan disc for errors and repair them when finished will automatically restart.
When restarted check the conditions when you had blue screen
Posted on Aug 01, 2008
    Genius:
  • 2,028 Answers
I had a machine through my shop recently with the same problem. It turned out to be a loose connection on the motherboard. I wouldn't worry about it too much, but if it persists or gets worse, especially when the machine is picked up or moved, then take the keyboard off and look for a loose connection.
  • Microsoft Master
  • 19,396 Answers
One of the hardware device is causing a conflict in windows, and that is the reason you get the blue screen.
Sometimes you solve the problem reinstalling windows.
More often you have to locate the part and replace or disable it.
Often you fix this problem replacing RAM modules.
Try replacing RAM, or if you have two modules run the machine only with one to test it.
It will be slower, but if it does not give the problem your replace the faulty RAM.
If you have no experience in working on electronics call a technician or take it to a repair shop.
If you DIY always work with power unplugged and do not touch chip contacts.
  • Microsoft Master
  • 6,487 Answers
This can be a driver problem if you want you can update all your devices driver to make sure they are using the correct software..
Hope that helps.........
  • Microsoft Master
  • 1,183 Answers
Generally the hardware malfunction blue screen comes , when there is driver conflict . The driver conflict can occur if there is an external printer or a webcamera attached to the system. If you got the screen only once there is nothing to worry. BUt if the screen comes up intermitttently, trying removing all external pheripherals except for keyboard mouse and monitor and thnen check the working of the machine
Thanks
proton
  • Mandeep  Singh
    Mandeep Singh Aug 01, 2008
    Yes,
    When you start your computer, tap on the f8 key slowly for 5 to 6 times .(need to do this before windows logo comes on the screen). Select safe mode on the screen using your keyboard and hit enter.
    If the system goes into safe mode select the administartor account. Once you see the start button after logging in . Try system restore.
    The other option is to run a repair of the operating system, for the same you would require a windows xp cd.
    Thanks
    proton
  • Mandeep  Singh
    GIve us the model and maufacturer of your system , so that we can help you better on the forum
    Thanks
    Proton
I have an IBM T41 type 2378 Windows XP Professional. I have been using and external monitor as the screen does not work. A while back I wanted to reformat my C drive and installed a windows XP disk I...
I would try to start it up in safe mode. This can tell you whether it's a display (physical) issue, or a driver (software) issue. You can do this by hitting the F8 button as soon as you start the computer and it brings up a prompt. At the Advanced system prompt, choose "Safe Mode with Networking" and see if it works then. If it does, I would suggest you undo an changes in the drivers that you made before.
Apr 01, 2011 | IBM ThinkPad T41 Notebook
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
The screen on my windows xp media center changed colors out of no where..red is black, blue is still blue but every othe ris color is green..how do i fix it..i already rebooted it and everything but dis...
Oh!!! no!!! ITS not the video card or what so ever rebooting will fix this problem.... its the monitor..... it is waht they called virtual chip inside the monitor that is malfunctioning, I already experience this problem.... and i will suggest that if your using basic monitor, which to an LCD monitor, its better.
Oct 12, 2009 | Microsoft Windows XP Media Center Edition...
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
Computer keeps rebooting
just check if you get a blue screen with lots of text messages just before your PC reboots. also if you have any hardware knowledge or if not ... get your vendor to check the RAM and also check if your CPU fan is working properly.... let me know...
Dec 03, 2008 | Microsoft Windows XP Home Edition
My laptop crashed over the summer; everytime I turned it on it would bring up the blue screen that says "begining physical memory dump" and a few times after that it would no longer turn on and i...
If you have win Xp go to start then programs then accesories then system tools then system information . Sorry about all the thens. when you get there click on hardware resources and conflict sharing that will give you some idea then you can click on componets and problem devices and see whats there. I hope that helps you
God Bless Greg
Nov 30, 2008 | Computers & Internet
Bought a refurbed dell d600 and it's a little screwy....
A blue screen can be caused by hardware or software. First let’s make sure your hardware checks out. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware. If the diags pass, (no errors) then you probably have an operating software issue.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 01, 2008 | Dell Latitude D600 Notebook
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Audio driver problem after upgrading OS from Windows 98 to xp
You could also try:
Do you have Service Pak 2 installed, it has a lot of updated drivers.
Remove all audio devices in the control panel > System > Hardware tab > Device Manager. Then reboot and let XP redetect the audio hardware.
Another idea is to run Windows Update and see if there's an update to the driver.
Hope that helps...
Geno
Mar 05, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
