When we fax something to someone our fax give them the information that it comes from B3 Debt Review.
We want it to indicate that the fax is coming from Johan Scheepers Inc.
Basically we want to change the sender details but don't know how.
Would you please be able to help us.
Regards
Sindy
FIXYA unpaid volunteers answer questions through the Internet, and are not able to represent you with your bank or credit companies.
You may want to ask a trusted relative or friend to help you as the words "killing me softly" suggest you are taking this hard, and need to keep a balanced view of life's problems and not let frustration prevent you taking positive steps to resolve the problem.
Test the fax setup from the control panel
Follow the steps below to perform a fax diagnostics test.
Set up the all-in-one for faxing according to the setup instructions found in the product's
User's Guide
Make sure you have inserted the print cartridges and loaded paper before starting
the test.
Press
Setup
6
, and then
6
This displays the Tools menu and then select
Run Fax Test
The HP all-in-one displays the status of the test on the color graphics display and
prints a report.
Review the report.
If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
If the test fails, review the report for more information on how to fix any
problems found.
After you pick up the fax report from the all-in-one, press
OK
. Then turn the printer off, and then on again.
If necessary, resolve any problems found and rerun the test.
Accessing the Diagnostic Utility from HP Solution Center
The
fax Diagnostic Utility can also be accessed from the HP Solution Center
software, by selecting the HP Fax enabled product in the drop down box,
and then following these steps:
Tab
through the Fax Setup Wizard to get to the end of the process. This is
a good opportunity to ensure that your fax machine is setup correctly.
Click
Click here to run the Fax Test
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
Review the report.
problems found.
OK
You can not do it by formulea but there is something called as ***-in you need to create add -in for this
I will suggest you that get a small program for doing this which will do all buisiness processing automatically will give you lots of benifits such as notification error catching and all.
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
