Question about Tally Line Matrix T6050 Printer
Thiruvallmy tally t6050 shows paper skipping - one blank page after one printed page. please help. i use fanfold size 10inch width by 12 inch height.
Phase problem facing t6050.
Posted on Jul 06, 2011
I want to add fanfold 8.5*12 option on wep 800DX printer settings.How to done it?
This is the answer I found on the website for this printer. I do not have any knowledge of this printer other than to look for information on the Internet.
How to do the custom page setting with Windows XP
Follow below steps for custom size of page in WinXP. 1. Go to Start - setting - Printers and Faxes 2. Select the printer for which you need to set the page 3. Click on File - Select Server properties - 4. Select "Create New Form" , and name the form. 5. Change the Height and Width of the forms as per available paper size. 6. Press Apply and save the form. 7. Now you can able to see the form name in the driver setting.
Mar 06, 2014 | Microsoft Windows XP Professional
I WANT TO SET PAPER 15'x12' . KINDLY HELP SIR
Press START - Printers and faxes - right click Tally Line Matrix T6050 Printer - select Printing Preferences - find menu Paper size, select paper with size 15"x12". If not found, select used define or customize - insert paper size (width and height) - OK.
Set paper size on Microsoft office word 2007 - select Page Layout - Margins - Custom Margins - select tab Paper - on Paper size, select Custom size - insert height and width paper (15"x12") - OK.
Hopefully help
Sep 23, 2011 | Tally Line Matrix T6050 Printer
How to add custome page size to tallygenicom 6306 printer with windows xp i have to use width 15in height 12 please rplay soon
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Sep 21, 2011 | TallyGenicom 6306 Matrix Printer
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
After creating a new form of size 15 x 12 fanfold in the printer settings option, form is saved but not applied. So after selecting printer in a software, the paper size option of 15 x 12 fanfold does not...
THe T6215 can only print a maximum width of 13.6 inches. If you create a form wider than this Windows will not allow you to select this form within the printer driver as the printer is not physically able to print this wide. Your paper may be 15 inches wide but it is unlikely you will be printing 15 inches, simply create a form whose width is equal to the maximum print width or 13.6 inches. You will then be able to select this form in the printer driver.
Dec 13, 2010 | Tally T6215 Matrix Printer
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
How to set fanfold 8.5 x 12 page in Tally 9
when you giving print command choose the printer and go to printer option and choose the paper type then give the print command .
Jan 20, 2010 | Tally T2245 Matrix Printer
When we give print command from tally software computer hang
The problem is related with the Papersize in Windows and PaperSize in Tally.
Usually your selected PaperSize in Tally and the LeftMargin.
Just adjust both (by pressing F12 function key, just before printing).
Please try the following steps, in sequence:
1. Select the printer, just before starting the printing.
2. Select the desired PAPER SIZE and return to Tally.
3. In Tally, press F12 function key and select the desired width and height of the paper, and also the Left Margin.
This will solve the problem.
Jun 25, 2009 | Computers & Internet
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Tally t2250problom
go in setup ,check paper ,inside size ,width,
select one that u want and save it & test
Dec 06, 2007 | Tally T2250 Matrix Printer
Tally Line Matrix T6050 Printer Logo
151 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
