SOURCE: jenn-air stove temperature not constant
Sounds like your oven probe sensor has got issues. Pretty easy to fix, just look inside oven for the probe (small round cyclinder, about a pencil width or smaller, mounted usually in the back top corners), remove the two screws, then slide it out. Some models have the probes where you will have to take the back off to get to them. If your probe is ok, then you might possibly have an issue with your main oven control, which may be computer or knob type. These (especially if computer driven) can be very expensive to fix, and some need calibration. Good luck and let me know if you need any other assistance.
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
SOURCE: trouble shooting guide
You can call any local goodman dealer/supplier and they can get you one. You can also try goodmanmfg.com. Your computer will need to be able to read pdf files in order to obtain info.
SOURCE: Robertshaw 9600: Temperature rises too high, fan doesn't stop.
My ac has worked fine recently, but then today it has started to act weird. The house was at 78 degrees and when the ac turned on it went to 80 degrees. What is the problem?
