The spin programme doesnt complete its cycle it jumps from 12 minutes to 1 minute.the fault diagnosis doesnt come on.
    Guru:
  • 262 Answers
If the unit was made outside of the U.S. I will not be able to help you.
Link for all appliance model numbers.
Please post your entire model number.
After you have clicked on the link below....
Just to the right of the "search" tab click on "help me find my model number"
Just click on the model of your choice In either video or image presentation
Then please repost the information.
Click on the link http://www.repairclinic.com/Appliance-Parts
Thanks....
Keith
Posted on Mar 16, 2011
Programme runs ok but once it reaches 1 minute remaining, the machine keeps on going & does not finish the cycle.
David it sounds like a timer problem, if newer machine the timer may be part of the board, which will have to be checked by a tech for repair or replacement.
Apr 08, 2016 | Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Programmer sticks before the spin cycle (number 5 and 9) on my beko washing machine also if you change programmes the programmer jumps round
Prog jumps as it will carry out 1st command selected unless reset.the sticking could be a faulty water solonoid valve if this happens say during softner fill although could also be the timer /programmer at fault
Apr 03, 2010 | Washing Machines
Machien was switched on and put on a normal wash but with 1 min remaining my little boy pushed some buttons and now it is jammed it only needed to spin for a minute but he somehow put it onto no spin. how...
Cancel programme, maybe you have an 'end of cycle' button. Switch machine off & take off plug from the wall socket for 15 minutes. Re-start programme with 'spin only', to rinse out your clothes.
Feb 20, 2010 | Washing Machines
In the full cycle it doesnt go in to rinse. It keeps on going in to the dry cycle
HI, this is a control fault here. unplug this unit for 5 minutes. this will reset the logic sector on the control board or timer module(depending on which model you have). Once the 5 minutes are up, try a new cycle. if this error continues after the reset, this will confirm my diagnosis. replace the timer or control board asap, in this case.
Aug 13, 2009 | Dishwashers
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
