Question about Vacuums
I have a stirella dual steam iron. At present it is constantly steaming even though the steam button is not clicked in place. How can I fix this?
    Sergeant:
    Champion:
  • 250 Answers
It sounds like the steam valve inside the iron is stuck open. You have to take the iron apart and free it up by lightly scraping water deposits off it with a screwdriver.
Posted on Mar 16, 2011
Heats up ok but no steam when temperature reached
Water indicator light keeps flashing and bleeping even when iron is full ,this is a brand new iron.
Sep 26, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Scrunci steamer no steam when the button (for steam) is pressed Vinegar has been used to no avail. Please advise. Thank you
Its most likely this iron is clogged with lime scale as you have already used Vinegar . Buy a lime scale remover liquid , mix it with hot water. And pour it into iron leave for 24 hours then empty , clean iron out to get rid of any lime scale solution. And try it again..
Hope this helps.
Apr 14, 2011 | Scunci 52067 Handheld Steam Vacuum
There appears to be a yellowy brown discharge that appears on my shirts when I iron. It doesn't happen all the time. How do I fix this?
Hi and welcome to FixYa, I am Kelly
Your iron is building up calcium deposits inside the reservoir and occasionally they flake off and into the steam system along with any minor releases of steam and it is showing up on your garments. There are commercial products in the market place for cleaning your iron.
This is one product:
http://www.google.com/search?q=Steam+Iron+cleaners&hl=en&safe=off&sa=X&rls=com.microsoft:en-ph&tbm=shop&prmd=ivns&tbs=brand:whink&ei=5_CWTevuNI-qcZe1masH&ved=0CJEBEMEJKAAwDg
This is another one:
Siege Chemical 776L Steam Iron and Showerhead Cleaner
http://www.siegechemical.com/00_cart_console.php?prod_id=522
It can be purchased from this page:
http://www.siegechemical.com/00_cartpage.php?cat=S-M
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Vacuums
Iron steams continuously even when staem switch set to off
Water still getting hot in there ,obviosly there is a problem with the switch or the liner in the iron just take the water out if you dont want it to steam
Feb 17, 2011 | Vacuums
My Sunbeam Pro Stream II Teflon shot and spray iron consistently spits water as I try to iron. I don't overfill it and the temperature and steam dials are set correctly. help!
How old is the steam iron?
And what type of water have you been using in it during its life?
The reason I ask, is that my Wife's was doing this, and we have fairly 'hard' water,
and she was using water directly from the tap.
After a year or so of this 'hard' water, calcium and minerals build up in the heating chamber in the iron-- Also passageways get clogged, and instead of smooth flowing steam, you get build-up of pressure, and then sputtering and spurting take place, as the clogged passageways try to pass the steam to where it needs to be.
Tell us more--
Mack B
Dec 28, 2010 | Vacuums
How do you take the casing of a stirella Simac SX4520D steam iron?
It have a torx-plus T20 screw horizontal under the handle.
Sep 26, 2010 | Vacuums
I was getting ready to iron a pair of pants that were polyesterrayon and 4% spandex. I thought I had my Rowenta iron turned down low enough but when I placed the iron on the pants they melted. Well...
First, UNPLUG THE IRON. DO THIS PART COLD. Clean the soleplate with scotch brite and WD-40. Next, you will have to remove the WD-40 residue from the soleplate with something like windex. Make sure you get around the steam holes.
Next-Plug it in and fill it with 50-50 mix of water and white vinegar. Set it for steam and let it run through. Refill it with plain water and steam it out again, until there is NO VINEGAR SMELL. This will clean the deposits out of the tank and steam vents.
Jul 04, 2010 | Vacuums
Vacuums Logo
743 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
