Question about Samsung ML-1640 Monochrome Laser Printer
Replace toer - Samsung ML-1640 Monochrome Laser Printer
  • 746 Answers
Follow my instructions.
Navigate through the menu of your laser printer using the keypad.
Choose "Replace Toner.
Select the cartridge that you want to replace (the printer will give you options of which cartridge you would like to replace). The selected cartridge will rotate to the inside front of the printer.
Open the printer door and lift up the handhold. Gently dislodge the cartridge for removal
Take a new toner cartridge out of the box and shake it gently. Remove the protective tape.
Insert the new cartridge into the laser printer and align the cartridge with the arrows. Push down gently to make sure it is locked into place.
Close the front panel of the printer, and it is ready for use. Print a test page.
Contact me for further more information.
Best of Luck
Posted on Mar 16, 2011
Just now toner refil but low toer eiiow led flasing problem
Because there is a chip on the toner cart once the orginal toner goes the chip tell the copier its gone you can refill all day but it will not change replace the image unit /toner cart.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 29, 2014 | Konica Minolta 1710587001 Toner, 1500...
All plugged in monitor sys no signal and toer jusy beeps any suggestions
check all ur coonection...hold power buttom for 2 min...and then restart pc...should solve the problem....
Oct 14, 2013 | Acer AL1916W 19" LCD Monitor
Tried voice chat. rings and connects but cant hear/speak to the person on the other end?
most likely with the headset you are using
make sure it has headphones and mike built in
check if volume of pc is on mute
check the ports behind the toer or pc you might connect them improperly
no any other major issues try to borrow a working headset from a friend it might help you isolate the problem
Hope it gives you idea.THanks
Mar 29, 2011 | Yahoo Messenger
I replaced both cartridges since the printer had not been used in several months. The left side of each page is comng out with a ink type smear on it. I imagine it needs to be cleaned, but do not know...
depends whats causing it
do a 10 page print job stop it when 2 are done and some prints are halfway through this can help u determine if its from the image drum where the image is put on the paper, the transfer roller or the fuser which melts the toer to the paper
Jan 19, 2011 | HP OfficeJet 6210 All-In-One InkJet...
TOER SLOW COOKER INSTRUCTIONS
There should be a middle position where the button sticks out half way at the top and bottom, this is low.
Jan 23, 2010 | Ovens
Error message in di620
my copier says toner colection box is full what can i do
Mar 16, 2009 | Minolta DiALTA Di620 All-In-One Laser...
Modle c4000 code c 0070
check that the toner bottle is in coreectly. remove the toner bottle and close the door. wait for the motor to stop turning (3 minutes) insert toner bottle with hole facing up.
Mar 05, 2009 | Pitney Bowes C180 Copier
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
Jul 06, 2007 | Brother MFC 6800 All-In-One Laser Printer
Samsung ML-1640 Monochrome Laser Printer Logo
21 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
