Question about Cavalry Storage Cavalry CAUG 500GB USB 2.0 White Portable CAUG25500W Hard Drive
I recently purchased a new Cavalry external hard drive (500gb, CAUG25500), and had been using it on my Thinkpad laptop with XP. It was working fine, no problems. Before a trip I was going on, I wanted to put some files from a previous laptop onto the hard drive, so I plugged it into the older laptop (a Dell inspiron w/ XP), and started transferring the files. The old laptop had far less battery power than I had remembered it having, and the file transfer was not completed onto the external. I then proceeded on my several-day trip with my external without using it once. Now, upon returning home and trying to use the external, neither laptop will recognize it. The external's light doesn't come on, there aren't any noises, and it doesn't show up under Disk Management in Computer Management. Any thoughts or help? I'd only been using the external for about 2 weeks, so I'll be pretty bummed if its end is already here. Thanks for any info!
    President:
  • 1,768 Answers
1. This could be due to several things.
a. The power supply for the external drive is not working properly
b. A broken power supply connector.
c. The USB drive was disconnected improperly > that is not disconnected safely in Windows
d. The external drive controller in the USB case is defective. A new case is needed.
Posted on Mar 18, 2011
External hard disk not opened,how i can open?
Opening the drive on the computer or physically opening the drive enclosure box? 500GB is so small it's not worth spending too much time on getting it working.
Oct 10, 2014 | Cavalry Storage Cavalry CADB001U32 1TB...
I have a cavalry CAUE37500 500GB 2.0 that I have literally used less than 50 times since I bought it a few years ago. I haven't used it for the last 6 months, but thought it was a good time to delete...
> ticking of a watch ...
A typical sound from a disk-drive that has malfunctioned.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
External hard drive will not power on
The adapter case could be faulty but the hard drive may be OK.
Remove the hard drive and connect it to an USB hard drive adapter. Then plug the adapter into a working computer's USB port and if this computer sees it as an external hard drive and you can open the folders and files, then the hard drive is OK and you only need to buy a new USB hard drive adapter case.
If the hard drive is faulty, and the data is very important to you, there are companies that can retrieve data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Jun 19, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
USB not reading in computer
try a new cable, and a different usb hub or a different pc, if not found, drive is bad
Apr 13, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Need driver for external hard drive for win 98
i didn't understand . you need not need extra driver for external hard drive for win 98.
if it is need what is the need of external hard drive
Jul 11, 2009 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Problems with cavalry 500gb external memory
The driver for this specific device is missing or corrupt. simply re install the driver information and, this will fix it.
Feb 17, 2009 | ACP Cavalry (CAUE37500) 500 GB USB 2.0...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
HDD won't work anymore.
Just change ( buy ) new external then put hdd on new external and everything will work fine!
Feb 27, 2008 | ACP Cavalry (CAUE37500) 500 GB USB 2.0...
Wd Hdd inaccessable
try to disable all firewall setings or antivirus...after try accesing frome ur command prompe if u can that the windows is blocking the hdd...uninstall any new software or driver and try again...no effect ok dowload ophcrack live cd frome google and access the hdd by force repare or scan it in surface scan that will fix ur clusters problems that might be in the back off this prob an du know wer e2 go frome there
Feb 12, 2008 | Cavalry Storage Cavalry CAUO37500 500GB...
Cavalry Storage Cavalry CAUG 500GB USB 2.0 White Portable CAUG25500W Hard Drive Logo
150 people viewed this question
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
