Question about Ovens
OVEN FAN STAYS ON AND DOES NOT HEAT UP - Ovens
    Problem Solver:
  • 8 Answers
I just had this problem with my gas range. It was the heating element. I don't know what kind of range you have but this appears to be the solution to this problem on many models.
It's not a terribly expensive fix if you do it yourself, but again, it would depend on what kind of oven you have.
Posted on Mar 16, 2011
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Oven heat varies
When you say it goes up and down by itself, what is the neon doing on the front panel. Is this switching off and on in relation to the oven heating and cooling? If it is, then it could be the thermostat sensor is dirty/covered in grease etc and giving false readings and will need a carful clean. With a fan oven, the fan should keep running, it is the element that the thermostat controls. If the neon stays on but the temperature varies, it could be a fault with the wiring. Does the fan keep running?
Jan 07, 2012 | Stoves Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
My smeg oven light stays on the fan does not work and the oven does not heat up. This has happened straight after I took the door off to clean.
Yes, I have had the same problem. The light in the bottom oven stayed on and the oven did not work after taking off the oven door SOLUTION: I didn't put the oven doo back on properly. Take it off and try again!
Dec 08, 2010 | Smeg Ovens
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
My neff oven b1664 rear fan element stays on after switched off
I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
Dec 11, 2008 | Ovens
Top oven has an error code (f2) It happen after a cleaning
F2 - Oven Temperature Too Hot - Depending upon model, replace relay (if present) or oven temperature sensor. Make sure to check sensor harness.
Dec 09, 2008 | Jenn-Air JJW8630C Expressions Collection...
Oven not heating up.
fault is the circular element found the fan. take back plate off inside oven and element is exposed. often but not always, you can see the damage to the element. element is easy to replace - usually held in by 2 - 7mm nuts on posts from the element base plate
Jul 06, 2008 | Stoves Ovens
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
