Question about Konica Minolta Office Equipment & Supplies
The toner isn't adhereing to the paper, If i change the settings to card it sticks
  • Konica Minolta Master
  • 32,281 Answers
The fuser unit is faulty or the power supply to the fuser unit is faulty. The fuser unit is not heating up to fuse the toner powder to the paper.
Try re-seating the fuser unit.
Posted on Mar 16, 2011
2 Suggested Answers
  • 230 Answers
SOURCE: toner does not adhere to paper
You have got a warped fuser this is the hot thing that cooks the toner onto the paper. Your best trying to locate a fuser unit for the machine this will solve your problem.
Posted on May 06, 2009
Can you print on 200gsm in the hp5550
200gsm what?
Usually there's a setting for thicker papers, which slows down the fuser, so that the card gets heated right the way through and the toner will adhere better.
Feb 12, 2015 | HP LaserJet 5550 Printer
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
I have Avery Gloss labels for laser printers and have a Ricoh laser printer. The black toner is adhering to the labels and the other colours are not
Look to your menu for a paper setup and find the one for label or card stock and choose that. Thicker paper or labels require more heat to fuser the toner to the media.
Feb 11, 2011 | Ricoh Aficio CL7200DL Laser Printer
Dell 3110cn Color Laser Printer Certain colors will not adhere to the page when printed on heavy paper. Combination of green/black wipes off the paper when rubbed.
Either the paper is just too thick for the printer to fuse the toner correctly, or you've NOT selected the right paper type (in the printer driver options.
If you're just printing that same as you would on ordinary A4 paper, the fuser can't get enough heat through the thick paper to fuse the toner.
May be a wrong toner problem if you've done this successfully before, but only had this problem since changing toner cartridge(s)
Oct 19, 2009 | Dell 3110cn Laser Printer
The toner of the printed document does not adhere quite well on the paper. Wipping wich the pand over the paper the toner will come off partly. I thought it was a problem of the toner, however after buying...
If you've been using Okidata original cartridges then it sounds like there's something wrong with the fuser unit in your printer. The fuser is what heats the paper to "melt" the toner onto the page. If you haven't been using Okidata cartridges, the one you purchased could either be laying down too much toner or low quality toner that can't be properly adhered to the page.
Oct 17, 2009 | OKI B4100 Laser Printer
Toner does not adhere to paper
May 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
125 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
