Question about Zoom X6 (5590) DSL Modem (55900003)
Wirless works for the netwoek but cannont connect laptops or i pods. they pick up the router but every password showing on the set up pages denies access
  • 32,281 Answers
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Posted on Mar 16, 2011
I am trying to set a wireless connection to a new laptop I have the Belkin router and for now using a cord, but it ask for a security network number and I've tried ever number on the bottom of the...
To get your wirless password (wep or wpa key) you can log-in to your router by typing in 192.168.2.1 in your address bar (Where you would type www.google.com)
After that you should a a page that resembles the one below:
Click the Security button on the side under wireless.
Next you will get a log-in page the password should be blank unless someone else set up the router.
Now you will see a page like the one below:
un-check the Obscure PSK box and that will show you the password needed to connect to wireless.
Hope this helps.
Bruce
Jun 14, 2011 | Belkin (F5D7230-4) Router (587009)
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
I have a Westell 327w My companies laptop connects fine but my daughters laptop will not. Her computer can connect to other wireless just not ours. Any help greatly appreciated
hi
may your wirless is prodected by password
just folow the setp
click on wirless icon on screen try to connect it will ask you password
if you don't know the pass then
in explorer type your IP e.c. http://192.168.1.1
then it will ask router password just apply then you will able to see your wireless password from the router setting
May 30, 2010 | Westell Wirespeed VersaLink...
Nb200 does not connect to wireless router ( dlink / virgin ) but will connect to neighbours unsecured wirless connection
you need to change your wirless settings.
I gues you have a high level security assigned to your router like WPA-PSK with a passphrase or WEP with 128 bit encryption.
Solution is :
Login to your router page and change the wireless security to WEP 64 bit and assign 10 digit number as a password in key 1. change your wireless name and click apply. and then try to connect to your own chnaged network.
Feb 26, 2010 | Computers & Internet
I am unable to enable wireless networking - the
So your on the GUI page of your router? you need to create the network name and password using your router connections. Make sure you have wireless adapter for you to be able to connect your computer wirelessly. If your having a problem to configure the wirless set up using your router contact your ISP.
Feb 21, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have cricket broadband wireless internet, how do i set up my belkin wireless router to it so i can send out a internet signal to another source?
You cna get the router manual on the below link free link
http://dl.owneriq.net/8/81c69071-e6b4-da74-6921-04cb37aa97a5.pdf
Also you can follow the below steps to set it up
Let me know if this will help
Regards
Dec 04, 2009 | Computers & Internet
How do you hook up a dynex 802.11g wireless router
To setup your Dynex router you can follow the below steps
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.0.1 and then type the username as "admin" and the password is blank so leave the password box as blank
  5. You need to set it up as per your internet service provider if you do not have any fixed IP address provided by ISP then select dynamic IP address and then click on clone mac address after saving these settings on the router setup page you can check if you are able to access internet then you can do the wireless settings
  6. Once the router setup page is open you can confugure the router easily without the CD setup.
  7. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  8. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  9. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  10. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  11. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Dec 03, 2009 | Computers & Internet
Unable to connect wirelessly to my laptop
I assume you are running XP.
1) Click Start then Connect to...
2) Click Show All Connections
3) When this window opens, find your router and select it
4) Right Click and select connect.
5) If it already shows connected then your router may have some security settings in place.
6) If you are connected as I said in step 5 then re-plug in your cable, open a browser and type in 192.168.1.1 and hit enter
7) If you get the login screen for your router then enter admin and no password.
8) Look at the settings under wireless and set up your laptop security to match the router.
Good luck and thanks for using FixYa
Mar 21, 2009 | Gateway Wireless-B Router (wbr-100)
Problems connecting to wirless router
Have you tried username 'admin' and password 'password'?
These are for the actual router.
Ifit's the wep/wpa wireless encryption password, then you need to go intothe router's domain page, it'll be something like 192.168.0.1 (or192.168.1.1 or 192.168.2.1 or 192.168.0.2) and enter admin andpassword, and then, usually under the Firewall menu, it'll say ResetFactory Settings. You can reset it and your wireless network should nowbe unsecured and you'll be able to connect to the internet wirelesslywith any device.
Hope this helps
Chris (ziraffa)
PS If all these numbers are doing your head in, just typewww.routerlogin.com into the URL box and it'll take you straight toyour router's domain page!
You can also go back into that page and set new passwords for encryption and also for passwording the actual router too.
Write them down this time! :)
Dec 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Zoom X6 (5590) DSL Modem (55900003) Logo
268 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
