Question about Candy 2.5 cu. ft. / 71 liter Upright Freezer CTVA110K
What temperature shoud it be on please - it has from 1 to 3
    President:
  • 1,489 Answers
I would suggest setting it on 2. But to eliminate guessing, the dial should be set so the temperature in the freezer compartment is 0 degrees F (-18 C). The best way to ***** this is to put a thermometer in the freezer and adjust the dial until the temperature is steady at 0.
Charlie
Posted on Mar 16, 2011
How do I reduce the freezer temperature
Locate the the thermostat - usually located in the fresh food compartment (if a refrigerator). Make small adjustments of about 1/8 of the dial's travel at a time - and check the change after 24 hours. Be sure to check both the freezer AND fresh food compartment to prevent temperature from dropping to low for fresh food. Best results are obtained by using a thermometer put in a glass of water in the fresh food area and another thermometer left in the freezer. Most manufacturers suggest a freezer temperature not greater than 0°F and fresh food 35°F to 40°F. If you need specific help with this - please include the make AND complete model number of your freezer.
Oct 23, 2015 | Freezers
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
My freezer is showing high temperature
Having up and down temperature. Sometimes is goes to +15 to -1. Please help me how cover this problem. Do i need to call a technician to this?
May 02, 2013 | Freezers
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
How do I adjust the freezer temperature on a Kenmore upright freezer?? Brand new, model number 461.27432, didn't come with a manual.. can't tell whether 7 or 1 is considered the coldest temperature?
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Kenmore Freezers
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Digital temperature buttons on upright freezer
Hi penshesh,
Happy to help.
This is the model # AFG7060
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 22, 2008 | Freezers
Candy 2.5 cu. ft. / 71 liter Upright Freezer CTVA110K Logo
208 people viewed this question
Top Candy Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Candy Freezer Expert? Answer questions, earn points and help others
