Question about Dell 946 All-In-One InkJet Printer
Printer can not communicate with the computer even after all cables are connected
    Sergeant:
    Champion:
  • 210 Answers
Check whether the printer is turned on?
check whether the printer drivers are installed... and whether the printer is getting detected or not...
u can check by:
right click my computer--> properties-->hardware--> device manager
in device manager check whether there is any yellow exclamation mark or red x.... if u see anything like that... check whether it is something related to the printer... so we will have to update or re-install the drivers
if u dont see any... then while the device manager is opened... unplug the usb cable with which u connect the printer to the computer.... wait for few seconds and replug it... while unplugging or replugging check whether the device manager is getting refreshed or not... if it is getting refreshed then the computer is actually detecting it... if not it is not getting detected.. check with a different usb cable
Hope this will help u...
Rate me if it does
thanks,
agnel
Posted on Mar 16, 2011
I am told I need a cable to connect the printer to the computer but the printer is wireless
You wouldnt not as long as you have a wireless router hooked up so the printer can communicate with your pc. If you dont have wireless router then yes you would need wire. Even though printer is wireless it has to communicate wirelessly with something..
May 04, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My printer doesn't seem to communicate with my computer even though I have the driver. When I hit print and select the DA 300, nothing happens.
It is possible that the printer driver is set to the wrong port. Is this a wireless or does it connect to the computer with a cable? You may have to change the driver settings to a different port.
Jul 24, 2010 | Pitney Bowes AddressRight DA300 Printer
Computer says there is no communication with the printer
Couple of things to consider and try,,,have you tried another USB device in the computer, like a flash drive? If it can read the flash drive ok then the problem is not the USB port. Try using a different USB cable for the printer. Make sure your computer is up to date with the most current drivers. To me it sounds like a bad printer cable. Another thing to try is having the printer attached and when the error message comes up try wiggling the cable to see if communication is restored. If so then chances are that the printer cable is bad. Hope this helps.
Jul 22, 2010 | Dell Photo 964 All-In-One InkJet Printer
How do i get my printer to scan????
Do you have the full-featured software installed? (This software must be installed before connecting the USB cable to the computer) Download it here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9098/9099&product=EKN033539
If you use a USB hub or a print server, try connecting directly to the computer. The scanner needs bi-directional communication with the computer to work. Try a new USB cable and a different port. (Even if the printer works, the scanner can lose communication.)
I hope this helps.
(if the scanner light does not warm up or sound like it is moving, you may need to service the unit - contact Kodak.)
Apr 02, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
My printer is not printing and give error message like ''communication error''. Is it because the cable is too long? I am using 10 ft now
Cable length has nothing to do with it. It may even be on the computer side as corrupt driver installation etc. Make sure the cable connections are correct. uninstall the device from the device manager and reinstall.
Sep 12, 2009 | Sharp AJ-5030 InkJet Printer
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
Jul 20, 2009 | Lexmark X3650 Printer
'Communication Not Available' message when printer cable connect
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Nov 18, 2008 | Lexmark X2250 All-In-One InkJet Printer
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Dell 946 All-In-One InkJet Printer Logo
54 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
